Schrader Valve - Not tapped!!
Old Oct 19, 2003 | 10:53 PM
Kuejo's Avatar
Car: 1988 IROC
Couldn't figure out why I was getting no pressure at the Schrader valve - so since I was swapping out the EGR and thermostat anyway, I decided to go ahead and pull the valve out of the fuel rail to see if there was some crud in there, or if I had a bad valve or something. It turns out that the machined fitting in the fuel rail never actually entered the fuel carrying portion of the rail!! It's a blind tap - goes nowhere, and accesses nothing, so I get nothing on my attempts to check fuel pressure!
I suppose someday I'll have to pull the rail and machine it the rest of the way, but it's too much trouble right now - gotta get it smogged by Wed, and so I think I'll save that for another day.
Oh yeah - and did you ever feel like you take two steps forward and one back? Busted the plastic fitting on the TV cable while I was taking things apart - so now I have to replace the TV cable - WONDERFUL.
Jonathan
Old Oct 19, 2003 | 11:03 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Re: Schrader Valve - Not tapped!!
Originally posted by Kuejo
...Oh yeah - and did you ever feel like you take two steps forward and one back? Busted the plastic fitting on the TV cable while I was taking things apart - so now I have to replace the TV cable - WONDERFUL.
Jonathan
hehe - That is the way these projects go. I am finally starting to get used to it . Weird about the schrader valve.
-Schultzy
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
