Code 13 ????
Old Oct 21, 2003 | 02:57 AM
1990irocz28's Avatar
Car: 1990 iroc 5.7
Code 13 ????
as soon as the car warms up it runs awful. Should replacing the oxygen sensor fix this?
Old Oct 22, 2003 | 03:27 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
probably. My car was running like crap and I got lucky one day and got code 13. Replaced O2, reset computer, runs great.
Old Oct 22, 2003 | 06:16 PM
rezinn's Avatar
Yes, sounds like that is the problem.
Old Oct 22, 2003 | 06:18 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
What he said.
The key part in your statement was 'as soon as the car warms up'. When the engine is cold, it's running open-loop, meaning the ECM is ignoring the oxygen sensor and using pre-set maps in the computer to determine the air/fuel mixture. Once the O2 sensor heats up enough to send the ECM a variable signal (when it's cold it sends a solid, non-changing signal), the computer uses the O2 to control its air/fuel mixture.
My buddy's car flashed a lean code every now and then, but stunk rich and only got about 14 mpg city...I told him to replace his O2 for months. When he finally did it, his city mileage went from 14 to 22. He thanked me very graciously.
Old Oct 23, 2003 | 02:30 AM
Car: 1990 iroc 5.7
ok i replaced the O2 sensor and reset the computer. I let the car warm up and went for a drive. I drove around slow at first and then i stepped on it and it started backfiring and knocking! I could drive it around but as soon as i go over 3000rpms it starts hesitating, backfiring, and knocking!! I dont know whats going on????
Old Oct 23, 2003 | 04:05 PM
RocZ57's Avatar
Are you using universal or OEM o2 sensor? I've had bad experiences before with the universal o2 sensor, so I stick with the OEM.
Old Oct 24, 2003 | 01:55 PM
Umbrarum's Avatar
Did it still throw code 13 after you replaced the sensor? Do a continuity check on the O2 sensor wire (follow it all the way back to the firewall). Smart money says it's burned through somewhere.
Old Oct 25, 2003 | 01:25 PM
Nixon1's Avatar
Unplug the O2 and drive. The computer should use a default table to calculate fuel delivery then. If the car runs much better, you'll know there's a problem in the wiring or the O2 itself.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
