Scanner readings with MAF unplugged?
Old Oct 24, 2003 | 09:37 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
According to my AutoXray my MAF is registering 3228gr/sec with the MAF unplugged and the car running or not. I've heard that the AutoXray can be inaccurate but I'm wondering what readings others are getting with it unplugged. Please let me know what type of scanner you are using also. Thanks.
Old Oct 25, 2003 | 12:30 AM
bigals87z28's Avatar
Car: Check The Sig
the readings your probably getting is the pre-set "limp home mode" setting the chip has if the MAF fouls up.
Old Oct 26, 2003 | 04:44 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
anyone else?
Old Jan 1, 2004 | 04:42 PM
Red88GTA's Avatar
Danny
What did you decide on this? My AutoXray is doing the same thing showing 1280 gr/sec with the MAF disconnected on my '88 L89 GTA. It also did the same thing on a buddies 1985 Corvette. Also on both cars, it sends them to a high idle when scanning. Did you ever try a different scanner than an autoXray to see if you MAF was functioning correctly? I am throwing no codes whatsoever, I am just fighting a BLM of 108 (rich condition).
Did see your other threads on this, but none of them had a conclusion.. Thanks..
Pat
Old Jan 1, 2004 | 06:53 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Yup, when the MAF is unplugged, the ecm automatically enters a limp home mode, which uses pre-set MAF values to keep the car running.
Old Jan 2, 2004 | 06:37 PM
Red88GTA's Avatar
Rob
Why does it give us numbers in the thousands instead of a preset number in the 0-255 grams/sec range. What gets me is why I don't throw a code neither. Any thoughts? Pat
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
mrdevontay
Sep 2, 2015 08:04 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Electro_X
Aug 19, 2015 07:59 AM
