Compatibility problems with 305's
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
I'm new to the GM camp too - first time owner of a performance car of any kind and I love it.
So, with the 305 TPI, which I have and am pretty fond of even if it's not got the bigger cubes, what are the biggest compatibility problem areas between the 305 and the 350?
I already understand that heads from a 350 you have to be very careful - that, or they just don't work. What about stuff like cams, cranks, etc - which main internal parts are compatible and which arent? I guess the bottom line is I'm still learning about the small block and I don't yet know what parts are exclusive to the 305 and which ones are used on both the 305 and 350.
I've been thinking about rebuilding my 305 - I don't want to go to a different block for more cubes because I want the car to have matching numbers. BUT - I've been thinking about blueprinting, maybe even stroking the 305. Has anyone heard of a stroked 305? Don't even know if it's something that can be done. In planning what I might want to do, I keep finding that I don't know which parts will work on the 305 when in the catalogs it just says "SBC" - so, any input here would be great.
Thanks all, Kevin
Thanks all, Kevin
Re: Compatibility problems with 305's
Thanks all, Kevin
Thanks all, Kevin
Car: 1989 IROC-Z
Yea you can stroke a 305 with power house's stroker kit. It raises the cubic inches up to 335. I heard though that they dont make very much power over stock anyway. But if I was goin to rebuild my 305 I would deffinatly put the stroker kit in. There are alot of people who flame this idea but its all on the owner to do what he/she likes. The big thing with the 335 stroker is that u have some serious cam issues hittin the crank. You cannot run a very large cam cause then the lobes hit the crank shaft rotating weights. Though someone on this board put a big cam in their 335 and just ground away the rotating weight so they would clear the cam. I dunno how safe that is but it worked! But to see real gains you need to port ur heads, people have gotten LB9 heads to flow better than stock 350 heads from goin crazy on porting. Then another thing to look at is when doin a stroker, is that strokers need air and lots of it so U want to port as much as u can to feed it the proper amount of air. TPiS here in minnesota is one of the greatest places to turn for high performance TPI stuff. They'll help u out where needed so u dont screw anything up. They are on the spendy side but take it from me they are worth it. (not everyone will agree though). But they make large tube runners that will make goobs of torque for u if you want ur stroker to do what its supposed to. I say do the stroker and let us know how its goin.
Jason
Jason
Car: '89 IROC-Z
bigals87z28, Fbirdta878787-
Thanks for the info and the warm welcome! I've been perusing the site daily for over a month or so now and reading like crazy. I've also purchased a couple of books about the TPI system and one specific to 3rd gen f-bodies that have been really helpful.
So, it's pretty much the rule of 305'rs - stay away from 350 heads. I read some where that people have machined the upper portion of the cylinders to accomodate the bigger chambers/valves - somehow that doesn't seem right - seems like that's the one place in the cylinder that you would want the most material to avoid catastrophic destruction of the cylinder walls.......
So, if 350 heads are a NO, then does one work over 305 heads or look to the aftermarket? I've only heard that World makes 305 heads - are they still making them and are they any good? Could I basically "make" a set of World heads with a very careful and thought porting job of GM heads?
I'm glad you guys seem to see where I'm coming from - I just think it would be fun to keep the stock engine and work it over. Right now, I want it naturally aspirated too - not really interested in a blower or NOS. See, I think it would be fun and challenging to take the stock engine and blueprint and balance it very well, do what one can to it through cam work, valve train work, and porting along with maybe some electronic mods and the use of high quality parts and try to get every last drop of power out of it that way - simply by improving upon the GM design, as it were. It's sort of like me saying I'm setting limitations on cubes and induction and then the goal is to get as much as I can out of it with those limitations. And of course, it has to be as durable if not more so than from the factory. Just me I guess.............
Bigal - it's funny that you mention doing a tune up and suspension mods - part of that has already been done and part is in the works. I already did a complete tune up - with 77k, I figure best to start from scratch. I put on a new cap and rotor, Bosch platinum plugs, MSD 8.5mm wires, new O2 sensor, new serp belt, new fluids all around including tranny and rear end, and of course a good grease job. The clutch had some chatter in it when I got the car so I decided to replace that while it was still working - a sort of preventative measure I guess. I'm putting on BMR control arms and an adj Spohn track bar just in case it gets new springs or new treads.
My plans are just coming together - at the heart of it all though is I want it to look outwardly original and have matching numbers and mostly original parts simply because it's an IROC - one day, the nice IROCs will be a rare thing I'm sure.
So thanks again for the welcome guys and do let me know what you think about 305 heads too.
C-ya, K
C-ya, K
305 heads, you have a few choices.
Porting your heads
I sugest you port the intake and exhaust runners, bigger intake valve (1.84 to 1.94), and have them mill the head for added compression. You can port the runners yourself with a die grinder, but the rest you need done by a shop. Then you can add whatever new valve train parts to your heads.
the World 305 SR torquers are basicly all that i decribed above, but for near 800 for a set. Thats a lot for just some 305 heads. they used to be cheaper, but I dunno, last year they skyrocketed another hundred bucks. You can buy them bare and make your own, but it doesnt matter. They are the best bolt on heads you can get
Vortec 305 heads require a lot of work also, including milling and porting to flow with the world heads. But you cant beat vortec head design. Only problem is, you need to get a different intake for the vortec head design. Thats extra $$$.
Then you have the aluminum corvette heads that will fit. These are the only 350 heads that will fit a 305 due to its small chamber. It flows better then the stock heads, and you will shave a couple of lbs off the car.
With all the heads, I sugest you think about a cam shaft. Several good cam chafts can be gotten from comp cams, and gm performance. Im going with a ZZ4 cam with possibly ported stock or if i can find them, ported SR heads.
Porting your heads
Welcome to TGO. Here is some good reading to keep you busy:
https://www.thirdgen.org/techbb2/sho...ck+Replacement
https://www.thirdgen.org/techbb2/sho...&highlight=305
db057
Aug 11, 2015 10:11 PM
