What is this called and what is it's function?
Old Oct 26, 2003 | 06:18 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Mine is cracked all up
sorry I should have used red to draw my box
it's just below the map sensor in the box that I drew
looks like a inline check valve or something
Thanks for the help
Old Oct 26, 2003 | 06:28 PM
llvll4l2c91350's Avatar
check valve that directs vacuum to the heater control vacuum motors (defrost, vent, etc.)
i think the other line attatched to it goes to the cruise control.
Old Oct 26, 2003 | 08:20 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
cool thanks
since I have deleted the A/C, heat and cooling, I should no longer need that check valve and could just place a coupler there correct?
Thanks again
Old Oct 27, 2003 | 06:11 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
IIRC you can just cap off the nipples on the plenum and be done with it. The other end does go to cruise.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
bschmale66853
Sep 30, 2015 08:11 PM
