TPI pings at WOT
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
TPI pings at WOT
Well, that pretty much says it all. She pings pretty bad up top around 4500 when the cars going from 1st to 2nd. Makes me hesitate to give it more, or keep at it. I feel as though something bad might happen. I ran a tank of 4-5 gallons 100 octane and the rest 91, and it ran pretty good, no audible ping. I am wondering what I can do about this? Would I need a chip burned? Any input will help., thanks fellas
Will
Will
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Ya Time'n, mine pings like a **** at 9* but runs great at 8*
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I'm with the others. If you aren't running lean then it is most likely your timing. Check that ASAP......that's how you blow head gaskets
The difference between 6º and 8º base timing in TPI cars can be tremendous
I will check the timing this weekend, but I am wondering how some simple mods might affect the a/f mixture. I have gutted airboxes, air foil, k&N's, descreened maf, 3" exhaust with a cutout. Might these cause me to run lean? In any event the timing is something I have been meaning to check
Will
Will
A friend of mine put a cut-out on his 97 and it caused him to ping like mad. Not sure Y but it did untill he put in an LT4 knock sensor.
Anyways, with the rest of your mods your getting alot more air into the motor.
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
