open element/maf???
Old Oct 28, 2003 | 09:32 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
open element/maf???
Are there any open elements available for a car with an MAF? Every open element setup I see does not have a MAF on it. Enlighten me please. Thanks.
Old Oct 28, 2003 | 10:02 PM
85TransAm406's Avatar
Car: 1985 Trans Am
why would you want an open element? you'd make more power with a DIY cold air kit.
Old Oct 28, 2003 | 10:13 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
You would want to buy a cone filter for an MAF setup if you wanted an open element.
It would be a better option for a cold air kit because you won't bring hot air in from the engine compartment.
Old Oct 28, 2003 | 11:16 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
Arent open elements a lot less restrictive though? Since the l98 has gobbs of low end torque I figure working on top end horsepower would be ideal, and I'm under the assumption that open elements are better for that area... Enlighten me if otherwise.
Old Oct 29, 2003 | 07:47 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Sucking in more hot is counterproductive, better to get a little less air that is much cooler, temps can get up over 200 under the hood
Old Oct 29, 2003 | 05:46 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
If you get an underhood ramair, or make one yourself,(which is not complictated at all) air will be forced in to an extent. The TPIs Intake design is what makes it run out of breath at high rpms.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
