zz4... plus what
Old Nov 1, 2003 | 09:11 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
zz4... plus what
ok it probably wont happen this winter because of my lack of funds... but in case i win the lottery, or just for the sake of my own knowledge and future use... this summer i plan to do a zz4 cam swap along with my header install. what else will i absolutly need, i figure common things will be springs, i want to go with 1.6RR (will they fit under stock valve covers?) and then i am not sure what. would i need a custom prom? also would i notice more of a gain if i also went with some of the SLP runners? thanks as always for the great info and help guys
Old Nov 4, 2003 | 10:14 AM
KYL98's Avatar
Car: 1991 Z28
Re: zz4... plus what
The ZZ4 cam works well in modified TPI engines. Anything you can do to open up the runners/plenum will help the cam do its job better. Also, since you'll need new springs, go ahead and have SCREW in studs put in the heads and have the spring pockets machined for the higher lift springs. Then a basic clean/pocket port on the heads will work wonders even for a stock motor. A custom prom is always good to make the most of any mod....but the car will run without it. MAF cars arent as sensitive to cam changes as a SD car is.....good luck
Old Nov 4, 2003 | 06:18 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
click the blue banner. you'll see what the dyno results are on my engine with the zz4 cam and other things.
Old Nov 4, 2003 | 09:35 PM
bigals87z28's Avatar
Car: Check The Sig
the zz4 cam is a roller cam... 86 is not a roller engine.
Old Nov 4, 2003 | 10:14 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The 86 was his first Camaro. He now has an 1989 IROC. By the way I will be installing the ZZ4 cam and flat top piston in my 1989 GTA soon. Have the Brodix street heads on it now and lots of goodies. Allen
K3000
May 11, 2005 07:47 PM
Chris89GTA
Mar 22, 2002 09:41 AM
kream-
Feb 1, 2001 12:25 PM
kream-
Aftermarket Product Review
Oct 27, 2000 02:35 PM
