A newbe needs help with TPI fiting new heads
Old Nov 5, 2003 | 03:12 AM
fast86's Avatar
Hi,
I just boought some some new heads they are the 034. Those are the GM Performance heads. They are the early 80's heads are really thick so the racer can port them.
Well I am lucky engouh to have a race ported ones that where ported buy some nascar builder gure claims that they flow over 300cfm at 600.
These heads are the Predistor to the Vortex. So they are the same still and bolt patern.
Know my question is Will my Stock Tpi intake bolt to it? If not what intake should I buy? (Just imagine there vortexs)
Ii want to keep the tpi but I dont know if I can bolt it on.
Thank you,
Shane
Old Nov 5, 2003 | 03:40 AM
Morley's Avatar
If they are the Vortex design, then no, your intake won't bolt to them. You'd need this http://www.sdpc2000.com/cart.asp?act...art&catid=1460
Old Nov 5, 2003 | 06:33 AM
fast86's Avatar
Dang those are exsspensive
I am trying to do this on a bugit. Will the lt4 intake fit?
Old Nov 5, 2003 | 07:55 AM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
No, LT4 won't bolt up. If they are the early style heads then anything pre-86 will bolt up to them. If you have a TPI from before 87 then it should work. If they are 87-newer heads you will have a different bolt pattern because of the canted center bolts. then you'll need a 87-newer intake to bolt up to it.
Old Nov 5, 2003 | 01:47 PM
kevinc's Avatar
Car: 1982 Z28
Re: A newbe needs help with TPI fiting new heads
Hi,
Thank you,
Shane
This guy's a BS artist, do a search on him...posted pics of "his car" which were actually a car for sale on eBay.
One month it's a 305 TPI, next month it's got a Quadrajet, etc...
Probably still rides a bike.
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
