Stealth Ram w/afr 195cc's.....?
Subscribe
Nov 5, 2003 | 06:39 PM
I recently bought a new set of afr 195cc L98 angle plug heads and ordered a holley stealth ram. Could anyone tell me what gasket I can use for this combo and what if any mods will I need to make to get them to fit together correctly...Thanks
Reply 0
Nov 5, 2003 | 06:49 PM
Reply 0
Nov 5, 2003 | 07:06 PM
Thats felpro right.....no mods needed huh?
Reply 0
Nov 7, 2003 | 08:34 PM
A Felpro 1205 should match your AFR's perfectly & some touchup port matching work on the HSR is all I did.
Reply 0
Nov 7, 2003 | 09:24 PM
Like Rick said.
However if you have never ported anything before dont worry about it as the 1205 is damn close to the HSR. Matching it up may or may not actually gain you anything as it flows damn near 300 cfm out of the box, exceeding the flow capabilities of the heads.
You would have though if the situation was reversed.
Reply 0
Nov 7, 2003 | 10:13 PM
http://www.stealthram.com/flowcomparison.html
Scroll to the bottom :P
Reply 0
Subscribe
