MAF ? and Cold air Kit ?
Old Nov 6, 2003 | 12:58 AM
89 TTA #901's Avatar
I have a 87 GTA 5.7 TPI and the mass air sensor is bad and i wanted to know what a good replacement would be aftermarket or stock ? my old maf is a Bosch ....also what kind of K&N filter cold air kit do you guys run on thes cars ? my car is totaly 100% stock
Thanks Jim
Old Nov 6, 2003 | 10:17 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Do a seach on Wells MAF. Off the top of my head I think is a SU-145.
Old Nov 6, 2003 | 08:22 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
On my 1889 GTA I installed the SLP cold air kit. Allen
Old Nov 6, 2003 | 11:43 PM
I'm going to buy the Wells MAF thanks for the info but i still need some advice on the some type of cold air kit ...whats the difference between my 87 and the 88-89 GTAs ? the location of the maf sensor ? and where's a good place to buy perf TPI parts from ?
Thanks Jim
Old Nov 7, 2003 | 07:48 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Here is the $12 cold air intake I made CAI
Old Nov 7, 2003 | 09:11 AM
Steve89GTA's Avatar
Want to sell your TTA? I'll throw in a MAF sensor too.
Old Nov 7, 2003 | 12:01 PM
No not the TTA ..but i would sell my 87 GTA hardtop 5.7 car and its all stock too
Thanks Jim
Old Nov 7, 2003 | 04:27 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
the difference between the 87 & 88-89 GTA's is the V-belt system. 88-89 got Serpentine belts. This forced Pontiac to use a very restrictive intake setup.
If you go with the SLP kit - you'll need all of the duct pieces. However, if you can find a wrecked 88-89 GTA or TA with the filtration setup intact - take it. Then all you have to buy is the SLP box on the end of the ductwork. All of the ductwork they sell that connects the box to the plenum is the same as stock.
Hope this helps
Old Nov 7, 2003 | 11:22 PM
Thanks anybody have TGRs cold air kit ? any pics of it installed ?
Thanks Jim
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
