Question about stock ford injectors
Old Nov 9, 2003 | 10:45 AM
NEOMASTERZ28's Avatar
Car: 85 z28
can i use stock 5.0 injectors off an 88 to replace my 85 135k injector. they were free from a buddy so i just took em.
will they work with out problems.
Old Nov 9, 2003 | 11:50 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Yeah theyll work just fine. Keep in mind Ford injectors are rated at a different PSI, so adjust your fuel pressure accordingly.
Old Nov 10, 2003 | 11:01 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
Ford 5.0 injectors=19 lbs.
305 TPI=19 lbs.
350 TPI=21 lbs.
Old Nov 11, 2003 | 10:02 AM
Car: 85 z28
will they work wit out modifacation i have afpr on there now so will they go on the fuel rail and in the intake with no probs.and will they give out he right peformance as the stock ones?
Old Nov 11, 2003 | 01:18 PM
Guest
Guest
Posts: n/a
305 TPI=19 lbs.
350 TPI=21 lbs.
Just ignore the above.
As for using them, you will have to lower the fuel pressure. The Ford injectors run at a lower PSI, and that 19 lb/hr the injectors are rated at is at that PSI. Throw them in there without lowering the pressure, the car will run rich.
Old Nov 11, 2003 | 02:04 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Actually,
350 TPI = 22 lb. injectors, not 21
MustangBeater20
Oct 29, 2022 09:20 PM
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 8, 2015 01:18 AM
