2032 cam + speed density + stock chip??
Old Nov 13, 2003 | 06:38 PM
RND91Z28's Avatar
I'm thinking about going with the crane 2032 cam (214/220 , .452/.465, 112 deg.) for my 305, 5 spd 91 Z28.
Anyone running this cam with speed density and stock chip? Who's done it and how did the computer/oem chip like (or should i say dis-like) this cam? Thanks
Old Nov 13, 2003 | 07:10 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
FWIW - I ran a 218/224 cam with a TPIS chip before I got into PROM Programming. I later found out that the fuel curves were IDENTICAL. For all potential purposes, I was running on the stock chip. Was it optimal? No. Did it work? Yes.
Tim
Old Nov 13, 2003 | 10:34 PM
llvll4l2c91350's Avatar
any gains with this cam before reprogramming?
Old Nov 14, 2003 | 08:04 AM
TRAXION's Avatar
Yes, I ran 12.5's @ 108 on the stock fuel curve with my fuel pressure bumped up to 52psi. This was with AFR190s and a fully upgraded LTR setup with a Vigilante 3600 stall. Normal stuff like headers and gears were done too.
Tim
Old Nov 16, 2003 | 05:31 PM
is 112 good enough for vaccuum on a stock TPI SD? i read that it's best to keep it at 114 which is the stock cam's spec.
Old Nov 21, 2003 | 06:04 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
speed density systems work real good with cams at 110-112 lobe sep.with 219-244 @.050 but beware they need moded chips,performance resources in nj,will take good care of you....
Old Nov 21, 2003 | 06:48 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Here's a graph of a person's car that I helped tune. It's a ZZ4 with a Stealth Ram using SD. The eprom was already modified by the company that put the engine/intake combo together.
FYI, the ZZ4 cam is milder than what you are looking at. But I hope you can see the differences between an "eprom that works, and eprom that is optimized".
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
camaro71633
Sep 1, 2015 10:24 AM
NWAsonoma
Aug 18, 2015 05:45 PM
86Base
Aug 8, 2015 01:34 PM
