Cold start injector for nitrous
Old Nov 19, 2003 | 08:55 PM
18436572's Avatar
Car: 69 Camaro
Engine: 355 SBC
Transmission: Glide
Axle/Gears: 4.88 full spool
Would it be possible to connect the cold start injector to a series of switches to add extra fuel for a dry nitrous setup and maybe a seperate fuel preasure regulator dedicated to the cold start injector to adjust how much fuel is deliverd . I've read about Grumpy doing this for his turbo but shouldn't this work for a little juice also.
Surely someone has done this on this board.
Old Nov 20, 2003 | 06:11 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
just the thought of a dry nitrous unit is bone chilling,you can tap into the rear of the fuel rail and use it to supply your WETsystem,if you had a DFI system it would not be too bad to have a dry system but then again its your engine.
Old Nov 21, 2003 | 06:38 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
I wouldn't trust it.
Old Nov 21, 2003 | 10:38 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The cold start injector isn't a good way to add fuel at WOT because of bad distribution.
A much easier way is to just add fuel for a dry system through the regular fuel injectors. To increase fuel through the injectors you could either raise the pressure with an FMU type device, or you can increase pulse width electronically with a switchable tricker box.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
