383 stroker oil pan clearance
Old Nov 13, 2003 | 08:36 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
i have a 383 stroker stock 89 block , will my stock oil pan baffle clear the stroke?
Old Nov 13, 2003 | 11:23 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
From everyone I have talked to, NO. Buddy said he got his stock pan to work though by beating the bottom down some w/ a hammer. You could try and see if it clears. But once you get the pan on, rotate the internals and see if you can hear/feel it hit.
Old Nov 14, 2003 | 05:22 AM
e-man's Avatar
Car: 89 formula
Engine: 383
mine cleared fine
Old Nov 14, 2003 | 06:58 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
No problem with the oil pan, however the windage tray had to be spaced out to clear the Scat crank. The big end of the rod to the cam lobe is the biggest concern though.
Old Apr 5, 2004 | 07:36 PM
weberusn's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Hey guys. I know this is a old post, but I have a question about the oil pan clearance. Where exactly is the problem with the clearance going to be? At the bottom of the pan? If so is beating it gently with a hammer going to help that problem?
Thanks guys,
Bill
Hotrodboba400
Dec 10, 2019 07:07 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
