Sdpc vortec head combo
Old Nov 14, 2003 | 09:20 PM
91 z28 350's Avatar
Car: 91 Z28
Upgraded Vortec Head Kit, Roller, TPI Intake, Headers
Price: $1,269.95
Part # SD8060RATPI
Chamber CC: 64cc
Intake Port CC: 170cc
Valve Size I/E: 14mm
Intake Flow @ .550": 0.708"
Tappet Angle: 1.250"
Valve Stem Size: 0.575"
Our Vortec cylinder head kit provides you with everything you need to install the new Vortec heads on your vehicle.
The upgraded, roller heads have been modified to accept our heavy duty Z28 valve springs with lightweight LT4 retainers. This produces a high reving cylinder head that can handle up to 0.575" lift hydraulic roller camshafts.
This kit includes Our Upgraded Vortec cylinder heads #SD8060A, head gaskets, head bolts, rocker arms, SDPC TPI Vortec Intake Manifold #12498060, intake gaskets and 12 point intake bolts.
Note: Includes our #SD3816 EGR kit for installing the EGR system with our Vortec TPI manifold with headers, headers not included.
Is this a good set up ? also what cam shaft would go good with this combo
Old Nov 14, 2003 | 11:19 PM
andyda98's Avatar
Car: 1988 and 1989 IROC_Z
Engine: 350 TPI w/ chip & 305 TPI
Axle/Gears: 2.77
SDPC
In one of the SDPC mags they had a about a three page article on the vortec TPI base plate. The only ? is if i buy vortec do i have to change any thing else on the engine
Old Nov 16, 2003 | 07:19 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
it sounds to be a good price for the amount of parts you are getting. They have a crate motor that makes 360hp with the LT4 hotcam in it. the only differnce would be the rotating assmebly.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
