tpi -> LT1 Intake
Old Nov 24, 2003 | 07:10 PM
morax2001's Avatar
tpi -> LT1 Intake
www.LT1intake.com
Is it worth the cash?
Anyone done it? What kind of results did you get?
Thank you
-Chris
Old Nov 24, 2003 | 07:32 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
yes it is,sweet performance..
Old Nov 24, 2003 | 07:57 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
do a search....good power gains in upper RPM.
Old Nov 24, 2003 | 08:02 PM
gen3z's Avatar
i also believe that you have to have a chip burned for the short runners and egr delete,as i see it you cannot go wrong with this intake,this does not rule out the other intakes such as:SUPERRAM awesome intake maintains tq numbers,LT1-MINI RAM you will suffer a little tq loss but larger hp gain,HSR flatout awesome design so depending on your combo any of these intakes could be the one to compliment your car,do your own research with the hp/tq numbers vs. your head,comp.ratio,camshaft and fuel delivery/msd or hi-6
Old Nov 24, 2003 | 09:52 PM
Guest
Guest
Posts: n/a
Going to the TPI board.
Old Nov 25, 2003 | 08:42 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Just make sure that a few people have already tried it on the heads you're using and/or they haven't been excessively decked. A few people have had issues with the intake not fully covering the coolant outlets on the heads, giving them a lower end full of coolant.
Other than that, they seem to work fine.
Old Nov 27, 2003 | 09:46 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
FreeBird is the ONLY person in my 2 years of LT1 conversions that have claimed to dump coolent into the oil.
I have had a few complain about coolant leaking ON TOP of the intake because the intake didn't cover the upper part of the water port of the head. These were fixed by welding additional material to the intake flange.
1992rs/ss
Jan 31, 2025 05:10 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
