Help! TPI starting problem
Old Nov 28, 2003 | 01:06 AM
denis's Avatar
Car: 80 Z28
Engine: just another 350
Transmission: th350
Friend of mine has an 85 trans am with a 350 TPI and it has sat off and on for 2 years. We went to go start the car up yesterday and it will just crank and crank without kicking over. It has spark but when i checked the schraeder valve on the fuel rail for fuel pressure, nothing happened. I swapped the relay for a known working one with no luck. I tried to find a FP fuse on the fuse block but there wasn't one and i looked near the battery for a fuse with no luck. Is the pump bad or am i missing something here?
thanks
denis
Old Nov 28, 2003 | 07:58 AM
Morley's Avatar
Do you hear the pump prime when the key is switched on? The fuse you are looking for is mounted to the fender in a little holder just to the rear of the battery about 8-10 inches, it is in a black holder. If that fuse is good and you don't hear the pump prime its time to start checking for voltage going to the relay, if there is voltage going to it, check for voltage coming out, if that is good check the wire run from relay to pump.
Old Nov 28, 2003 | 06:18 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I had a similar problem, everything was there except the fuel pump wasn't priming, ended up being the fuse by the battery on the fender.
Another way to check if it's that fuse is by putting the key intot he on position and looking for the SES light, if it doesn't come on then it's the fuse, the fuse powers the fuel pump & ecm.
Old Nov 28, 2003 | 11:08 PM
denis's Avatar
Car: 80 Z28
Transmission: th350
I couldn't find a fuse anywhere around the battery, all i found were some red wires and red/white stripe wires. I do not hear anything going on in the tank either.
Old Nov 29, 2003 | 08:56 AM
5SIZ's Avatar
Car: 1987 IROC-Z
did ya put the key in the on position like I recommended to see if the ses light comes on??? if you want to make sure it's that fuse then try it.
Old Dec 5, 2003 | 03:21 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Hey, where is that fuse your talking about. Possibly, do you have any pictures of this ?
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 8, 2015 12:07 PM
