Help hooking up Charcoal Canister
Old Nov 29, 2003 | 09:44 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I am putting my new motor back together and I can't for the life of me figure out how the charcoal canister is supposed to be hooked up. I don't know if this matters but its a 350 speed density setup.
The canister I'm using has the electric solinoid on it. Attached to that solinoid assembly are two vacuum ports, the top port is smaller than the one on the bottom. Now totally seperate but on that same vacuum canister is another vacuum port with an even bigger port than the others (this one happens to have some kind of cover on it).
I also have this piece that says Rochester Products Control Vac. This has a small vacuum port going in on the top and two bigger ports that exit both sides on the bottom
With that said can somebody please tell me how all this is supposed to be hooked and where everything is supposed to go. Pictures would be great if you have them.
Old Nov 30, 2003 | 08:28 AM
Larry's Avatar
Car: 86 Corvette
Just PM'd you the diagrams for 91 SD charcoal canister
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
