Fuel Pump Help...
Old Nov 29, 2003 | 09:08 PM
SweetRide45's Avatar
Fuel Pump Help...
Ok, well, my question is, I'm changing out my differential soon, and I figure, since I'm at it, I might as well swap out the fuel pump. I have a '90 Firebird 3.1 mpfi. I'm also planning on swapping in a 350 TPI Crate from sdpc. And I want all the pressure that thing needs, w/o going back up to swap the damn pump out. Now, would my 3.1 go hay-wire w/ a V8 pump in there? I'd figure my stock regulator would still keep it at what my v6 needs, and it shouldn't be a problem.
Also, what is the best pump to get that would flow what the "Future" engine would need, and would last the longest and is most reliable?
Any info would be greatly appreciated.
Thanks!!!
Old Nov 30, 2003 | 02:53 AM
Morley's Avatar
The stock pump for a TPI car should do just fine for the crate engine. And since the V6 is MPI, then the pump for the TPI should be ok in it.
Old Nov 30, 2003 | 01:55 PM
ok, thanks for your help!!!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
