Jumpy Oil pressure gauge
Old Nov 30, 2003 | 05:56 PM
DrekkenX's Avatar
Hello there, I hope everyone had a great holiday, :-)
Every once in a while my oil pressure gauge will jump around. Sometimes it wil pin itself passed 60psi and then drop back to normal and hop around. Then it goes away and doesnt happen for another couple months. Any thoughts? Maybe the sending unit? Thanks in advance
- Tom
Old Nov 30, 2003 | 06:01 PM
llvll4l2c91350's Avatar
crappy sending units + innacurate gauges = common thirdgen F-body problem.
very likely
Old Dec 1, 2003 | 12:02 AM
STIFFLER's Avatar
Oil pressure sensor... I had the same thing and was fixed with a new on from the dealer...
located above the oil filter cylinder looking unit with and electrical plug in it...
Old Dec 1, 2003 | 07:52 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
If it is the Oil pressure sensor, I'd get it fixed fast. Mine went and about a day later I had the fastest oil leak EVER!
Old Dec 1, 2003 | 08:07 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
That can also be a sign of a bad/spun bearing, I have a mech gauge in my vette and had a main bearing go, the pressure would jump around during high rpm usage, above 3000.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
