Are these numbers low??
Old Dec 2, 2003 | 10:04 PM
bohn333's Avatar
Car: 1987 Trans am
243.5 HP at the wheels, 4500RPM
306.7 TQ at the wheels, 3800RPM
Heres everything that is done so far.
Block: 1997 four bolt roller block.
Piston: Stock L98
Crank: Stock L98
Cam: Stock L98
Heads: GM Vortec
Rockers: 1.6 roller
Intake: SCPD base, edelbrock runners
Plenum: Stock, ported
TB: 58mm Edelbrock
Injectors: Stock 22#
Headers: TES edelbrock
Exhaust: 3" with flowmaster muffler no converter
Ignition:Stock
Other things include custom cold air kit made by myself. Custom burned chip, by jimsperformance.com ( awsome chip, perfect fuel / air mixture )
I thought these were good, but the more i read up the more they seem low to me. Anybody have any suggestions.
Old Dec 2, 2003 | 10:29 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
Theses #'s seem pretty normal.
Old Dec 3, 2003 | 12:05 AM
OMINOUS_87's Avatar
There is more potential with a decent sized cam in that motor.
Old Dec 3, 2003 | 02:33 AM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
Yup, get a good cam and a tune, and you should be putting down some killer numbers. Those are already good enough to take out some LT1's.
Old Dec 3, 2003 | 07:02 PM
bohn333's Avatar
Car: 1987 Trans am
i picked up an LT4 hot cam, so that will be going in. I have to take the heads off and get the spring pockets machined. So i will be going with a thinner headgasket...should put it up to 9.5 to 1 from the now 9.3 to 1. I might look into doing some port work on the heads..Vortecs can be improved on the exhaust side very easily. I can still do pulleys and coolant bypass mod too.
I hope this will put me at 300hp at the wheels.
Old Dec 3, 2003 | 07:32 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
300hp at the wheels? im not really sure about that. if you do that would be sweet because id go that direction with my 400. but id say more like 270ish i think. i know there are alot more people that are more experienced on this and would probably correct me if im wrong so im just going to send this and wait for some replies
Old Dec 3, 2003 | 07:54 PM
bohn333's Avatar
Car: 1987 Trans am
i would be happy with 270 to 280 at the wheels. I would be close to LS1 territory.
Old Dec 3, 2003 | 08:08 PM
Car: 85 Camaro Z-28
Engine: 6.6
yeah that would be very cool, are you going to run it on the dyno after the cam ect? if you do please post the numbers, im interested in the results. or seat-of-the-pants would be fine too <thats what your gonna look like.....
Old Dec 3, 2003 | 08:17 PM
bohn333's Avatar
Car: 1987 Trans am
i'll run it on the dyno..it won't be till early next year though. I'm in no hurry, i have till april to get it done, the local track doesn't open until then.
Old Dec 3, 2003 | 08:22 PM
Car: 85 Camaro Z-28
Engine: 6.6
BTW: How much is it to run your car on the dyno, i am not sure there is any dyno's around here that i can drive my car onto but i seriously have no idea what they would charge, i nkow they had a portable one at a carshow and some cars ran but i didnt go to that show.
Old Dec 3, 2003 | 08:40 PM
bohn333's Avatar
Car: 1987 Trans am
Its $50 for three baseline runs and another $15 for an air / fuel measurment. When i went before the guy pulled five runs with it and only charged me for the three...nice guy. Its in Greenville WI, its only about 15minutes from my house, so i got lucky on that.
Old Dec 3, 2003 | 10:01 PM
Car: 85 Camaro Z-28
Engine: 6.6
im going to have to find a dyno around here, for one im sick of havin to cross the border to go drag race(canadian border) its about 30-40 min. away. but also the nearest dyno i think is in burlington VT which is about an hour away maybe. and i think its an Engine only dyno. but who knows, i can probably ask around and find one somewhere close, if i had the money id start my own drag strip. indoor! lol now that would be awsome, drag racing all year around!! WHOO HOOO!!! :lala: anyways good luck on your car!
Old Dec 3, 2003 | 11:49 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Work the heads. Also, I know you probably have an in on an LT4 cam, but there could possibly be a better match - I would call up comp and see how much thier recommended cam differs from the LT4 specs to get an idea of how much closer you can get.
Are those edelbrock runners cleaned up and port matched? If not do that too! With a smooth transition LTR setup, some work on the Vortecs, and a matched cam you got more than 300RWHP. The torque should put you in the backseat if you get my drift
Old Dec 4, 2003 | 07:58 PM
bohn333's Avatar
Car: 1987 Trans am
i called comp today and they recommend a very similar cam, little more lift though, and about twice as expensive. I'll stick with the LT4 hot cam. I did port the runners, but i think i could do some more work to them. I plan on concentrating on the exhaust side of the heads..on the intake they flow great. I should be able to pick up about 20hp just with a mild port job.
Old Dec 4, 2003 | 10:23 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Well then there you go - I'm thinking you'll see borderline 300RWHP (give or take about 10RWHP)
I am surprised the LT4 cam matches Vortec heads... wierd.
Old Dec 5, 2003 | 01:29 AM
OMINOUS_87's Avatar
Be cautious in your cam selection. The Hotcam has an excessive amount of exhaust duration for what a TPI system likes.
The TPI intake is a tuned system that delivers a real pop to the velocity of the intake charge. Hanging the exhaust valve open for too long can affect cylinder pressure adversely due to an overscavanging effect.
Rambling on, the Vortec head sports a week exhaust port, however it is easily able to be worked for greater flow potential.
A strong exhasut port and a big spread in duration may not be the direction you want to go. Best performance will come from a cam that is best suited to your airflow needs, no the cam that is on sale.
Jorlain
Oct 8, 2015 01:57 AM
fasteddi
Sep 10, 2015 09:32 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
