stealth ram
Old Dec 10, 2003 | 05:45 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
stealth ram
i know thet stealth ram is not emissions legal but that's okay. i was looking at thunder racing and it seems that it would only be about $600 for the set up non polished. what else would i need to make it work on my gta?
Old Dec 10, 2003 | 05:49 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
Actually it will come to 498$ for the manifold and fuel rail w/ the AFPR, I just ordered it! You get 20$ off just for ordering it online. Can't beat that!
Old Dec 10, 2003 | 06:14 PM
stevedave454's Avatar
Car: 91 S10
if you have TPI already then you shouldn't need anything else to get it to work, besides standard gaskets if they didn't come with it, it will use all the sensors, throttle body, etc you already have
Old Dec 10, 2003 | 08:08 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
Actually, it takes a bit more than just the gaskets.
You need a TBI thermostat housing, different radiator hose, assorted hose nipples, new upper radiator hose, different fuel lines, etc.
The fuel lines, depending on how you do it, will be the most expensive. I did Aeroquip socketless hose and I think it set me back about 75 bucks. The other stuff is mostly incidental. Unless you have a 85 or 86, then you have to switch distributors.
Check out http://www.stealthram.com , they may have the info you need. Might also check out http://www.chevytalk.com and do a search for stealth ram. There was a very detailed list of needs there at one time. Actually it's probably here too, but I don't surf here much, so I don't know for sure.
As for the price, it must have gone up a bit after it was first released, as I paid 475 for mine and it came with the adjustable regulator.
Old Dec 10, 2003 | 08:49 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
click the green banner and go to cost to swap and you'll find most of your answers there.
Old Dec 11, 2003 | 10:33 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
is this going to fit under my stock hood?
Old Dec 11, 2003 | 10:41 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
http://members.***.net/jmatlock88
Lots of stuff to answer your questions also... (including hood clearance pictures, etc)
Old Dec 12, 2003 | 12:34 AM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
so it should fit under a ram air 2 hood no problem?
Old Dec 12, 2003 | 01:53 AM
JMatlock88's Avatar
Car: 1991 Formula
Yes.
Old Dec 12, 2003 | 12:56 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
Only the 85 and 86 distributers will work? My 92 has an external coil so I thought I'd be ok with it, am I wrong?
Old Dec 12, 2003 | 07:07 PM
JMatlock88's Avatar
Car: 1991 Formula
No, the external coil HEI distributor that came factory on your car will work perfectly.
Old Dec 12, 2003 | 07:38 PM
Car: 92Z28
Transmission: A4
Cool,
I am keeping that on my to do list then.
Thanks,
Charlie
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
