Sneak Preview - E-tec TPI
Old Dec 11, 2003 | 12:22 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Hello everyone, its been a while since I've posted, but I've been working on a new project (1991 GTA Trans Am)!! Here's a sneak preview of my E-tec Vortec TPI!! I'm really digging the monochromatic color scheme I'm going with!
Can't wait to get my prom burning equipment and get rolling!!
Lemme know what you think!!
Old Dec 11, 2003 | 12:23 AM
thirdgen88's Avatar
Car: 1995 Corvette
Another Pic
Here's a pic with the water pump
Old Dec 11, 2003 | 12:30 AM
thirdgen88's Avatar
Car: 1995 Corvette
One more with the GTA in the Background
Gotta see a little of the new beasty..
Old Dec 11, 2003 | 01:05 AM
cdartz's Avatar
Looks great.
Old Dec 11, 2003 | 10:19 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Cam specs, compression, E-tec 170 or 200 ?
Old Dec 11, 2003 | 10:36 AM
OMINOUS_87's Avatar
That intake doesnt look ported.
I would recomend putting some work into it.
Old Dec 11, 2003 | 12:20 PM
thirdgen88's Avatar
Car: 1995 Corvette
Well, you're right in that the head ports need some work, but the runner ports are matched to edelbrock runners..
Old Dec 11, 2003 | 12:24 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Lookin' good so far!
Specs dammit, we need specs!!
Old Dec 11, 2003 | 12:25 PM
thirdgen88's Avatar
Car: 1995 Corvette
Cam specs
Here's the link to the cam spec sheet... its a xr258hr-10
http://www.compcams.com/Technical/Se...umber=08-408-8
Oh, and they're etec 200's... I probably should have gotten the 170's, but I bought the heads a while back.. Room for the future, anyway..
Compression I'm not sure about... Edelbrock says that you'll get 10.2:1 with flat-top pistons; I've got the stock pistons with 4 valve reliefs (flat-top?) and 1003 felpro head gaskets..
Old Dec 11, 2003 | 03:37 PM
OMINOUS_87's Avatar
If your block hasnt been decked then you are going to have alot of excess quench height by running the 1003 head gasket. The 1003 is designed to be run on a motor with zero deck height.
If you are running an L98 factory shorblock then your compression ration will be ~9.25:1.
Old Dec 11, 2003 | 04:17 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Why are you running that small of a cam? You would make ALOT more power with a bigger cam!
Is it in you budget to change it out? If so, the Comp Cams XR269HR-12 would be GREAT for your combination! It would probably get better emissions too due to the bigger LSA of the above mentioned cam.
Just trying to help!
Old Dec 11, 2003 | 08:17 PM
thirdgen88's Avatar
Car: 1995 Corvette
Yeah, its a fairly tame camshaft by comparison.. Originally, I wanted one that would play nicely with an ecm for a future fuel injection setup (this was back when I did the v6-v8 swap in my 1988 red firebird, which suffered a fire a month ago). At this point, I've simply pulled the drivetrain from that bird and am working to put it in my new GTA (going EFI this time as opposed to performer rpm with eps 800 carb).. I know I'd possibly be better off with the cam you listed, or possibly even the one in your motor, but it performed well under the carb induction (and that was never perfectly tuned) so I'll try it for now...
Old Dec 11, 2003 | 09:02 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I agree with 1badz, step it up now!!!
I am sure it will work out pretty well, but in the long run you save yourself from aggrevation of changing it out with the engine in the car. Just my 2 cents.
That paint scheme looks awesome, I bet it will look incredible in the car too. Nice job
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
