How does TPI compare?
Old Dec 11, 2003 | 06:23 AM
KtuluX's Avatar
Car: 87 Trans Am
Engine: 5.0 TPI
Transmission: Automatic
My roomate just bought a 95 Mustang GT. His quote was "see that, GT" I said "yea, 87 TA with TPI." My question is this... how does his 5.0L HO Ford Motor compare to my 5.0L TPI Pontiac Motor? Just curious.
Old Dec 11, 2003 | 11:54 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
One makes torque and one does not.
Old Dec 11, 2003 | 11:58 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
If your GTA is in good tune, you should be able to take him by a couple of car links.
Old Dec 11, 2003 | 02:11 PM
ULTM8Z's Avatar
If I remember correctly, the 5.0L Mustangs routinely trounced the 5.0L Camaros and Firebirds. I think it had a lot to do with vehicle weight though. I also believe the bore/stroke combinations were different between the two. The Ford had a 4.00 bore with a 3.00 stroke, whereas the Chevy (and correct me if I'm wrong) had a 3.75 bore and a 3.48 stroke.
You'd think the Chevy would make a lot more torque with almost .5" more stroke, but it actually made less- 275 ft-lbs (Chevy) vs 300 (Ford). I think the cam in the 305 was so anemic that it really hampered the Camaro.
Old Dec 11, 2003 | 02:12 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
LOL.... how very true!!! But, I wouldn't give 'that' much credit to the anemic 305.
This mustang, if it's a stick... will give you a good run, and if you're running stock with an automatic, he might just take you!
Old Dec 28, 2003 | 12:31 AM
bonz's Avatar
Car: 89 GTA
I raced a 2002 mustang GT which had a manual and took him, and that was before most my small mods and new exhaust. It was close but still took him. However i did get took by a mid 80's mustang but it was a police intersepter with 4.11 gears and my 2.73's cant keep up with that in town.
1989 Trans am 305 TPI Automatic, 2.73 rear, K&N filter, underdrive pulleys, air foil, tb bypass, low restriction exhaust
Old Dec 28, 2003 | 02:09 AM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
Re: How does TPI compare?
Originally posted by KtuluX 5.0L TPI CHEVY Motor?
fix it for ya
yeah you should be able to take him
Old Dec 28, 2003 | 07:26 AM
vwdave's Avatar
I personally think he would get ya.
Old Dec 28, 2003 | 10:27 AM
Verviticas's Avatar
Engine: L98 5.7
If your stick and he is auto i think it will be close, a good race if you ask me. If he is stick and your auto then you'd better hope he doesnt know his car very well. Mustangs are fast little buggers. But the 5.7 is an easy win. My buddy has a 5.0L Capri (almost identical to mustang) thats mildly modded. He cant even touch my 5.7GTA. I usually burn out for a couple seconds just for show before i blow him away.
Old Dec 28, 2003 | 11:42 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
stock for stock the 5.0 Ford is superior to the 5.0 Chevy...
Still, not much. Do a few breathment mods and you'll pass him.
Old Dec 28, 2003 | 01:37 PM
zerotosixtyV8's Avatar
Car: Camaro
95 GT stick should run a 15 flat, which is faster than any auto 305s I know of, if it was a lighter fox, I'd say you wouldn't stand a chance unless it's an auto for both cars. are you a manual 305?? if so you'd have a good run. the only dogs are the 96-97 GTs, those 4.6s are a turd and a half. they make 305s look good lol
Old Dec 30, 2003 | 05:51 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Race him and find out, this should have been settled the day he brought that POS home.
Old Jan 10, 2004 | 06:49 PM
Eric_7810's Avatar
Car: 1986 Z28
Engine: LG4 305ci
Get ready to lose....
Old Jan 16, 2004 | 02:54 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
A 5.0 MUSTANG 5 SPD, WITH A DRIVER WHO CAN SHIFT WILL BEAT ANY STOCK TPI F-BODY, IF IT WERE AN 86-92 FOX. THOSE CARS RUN 14.0'S AND FASTER COMPLETELY STOCK. NOW, WITH THAT SAID, A 95 MUSTANG 5.0 ONLY MAKES 215 HP, AND IS MUCH HEAVIER THAN THE OLDER BODY STYLE. IT WOULD BE AN OK RACE IF YOU'RE BOTH MANUALS, OR AUTOMATICS, BUT I WOULDN'T BET ANYTHING THAT YOU CAN'T AFFORD TO LOSE.... GOOD LUCK!
Old Jan 16, 2004 | 03:53 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
The 305 TPI of 87 ran around a 15.4 or so, so you are off by a few clicks Vs the Stang, maybe if someone was to bump him Hmmm..... j/k
Anyway, I have a 85 Iroc with a rebuilt 305, small cam, headers, a/c delete and a airfoil(I didn't feel any difference btw) and I took care of my cuz's 96 GT that only had a exhaust and K&N. It was a good little race. Off the line you will get him but after that it is a matter who drives better and shifts better. Good luck!!!
Old Jan 19, 2004 | 12:25 PM
Car: Camaro
a 95 5.0 makes comparable HP to a stock fox. my friends 89 5.0 vert ran a 14.4, as did my 350 IROC and we both had our share of tune up issues, I wouldn't say it was any faster than mine stock for stock. I've heard 13.8 out of a coupe, but it was driven so hard and so well I doubt any body could pull it off on the street. it also had slicks.
Old Jan 19, 2004 | 12:46 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
id love to be the one who proves you wrong...my G92 LB9 with a flowmaster, K&N, the EGR walls ground down and me driving it like it should be ran a 14.1@almost 97....i dunno about you, but that will run all over a LX 5 speed...and LT1 and L98...and would leave a 94-95 5.0....those 4.6's? haaaaaaaaa lol......
Properly driven a G92 LB9 will whoop any L98 car as i have...DAMN THOSE G92 L98's
Old Jan 19, 2004 | 12:52 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Thats a pretty bold statement...
Old Jan 19, 2004 | 01:15 PM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
look most mustang new or old run low 15 high 14s with a crappy driver you need to run a mid 14 to even come close to beating him i know from experience i run a 14.5 and get beat by ones that just have exhaust,they reason they are faster is they are lighter thats it, but with the newer ones you have a better shot because i was racing 02 GT WITH A GRAND MARQUIS last night we were rollin already buit i still beat him.newer they are the weaker they get. good hunting though
Caspar
Jun 19, 2016 11:19 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
88TPI406GTA
Convertibles
Aug 27, 2015 07:01 PM
Randomtask2
Aug 26, 2015 03:34 PM
Sanjay
Aug 12, 2015 03:41 PM
