gas tank leaking badly
Old Dec 13, 2003 | 11:41 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
A lot of people say this is just a small leak, but this is beyond a pinhole leak, I have had two thirdgens, and I have never experience this. On hard cornering, and a full tank, the fuel spills out the filler door and down the quarter panel. I can wiggle the filler neck with some play, and it has a clicking noise, which leads me to believe that the weld there is somehow damaged. Anyone experience this before??? Is it worth it to get a new gas tank, my mileage has dropped significantly I'm losing so much fuel
Will
Old Dec 14, 2003 | 06:23 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Its time to find out where the leak is before thinking about a new tank. Just my opinion.
Old Dec 14, 2003 | 02:29 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
I had an 86 Trans Am with a severly leaky tank. I would loose like 2 or 3 gallons overnight. I had to replace it, and it was not easy. The rearend has to come out. The filler neck is soldered to the tank, so fishing the old one out is hard, and putting the new one is is almost impossible without "modifying" the inner quarter panel. Not to mention the aren't cheap. Expect about $200 for an aftermarket one, and $400 for a GM piece.
Old Dec 14, 2003 | 06:55 PM
Screamer27's Avatar
Car: 1986 Monte SS / 1988 Iroc-Z
Engine: LS3 / L98
Transmission: 4l80E / T56
Axle/Gears: 3.73 / 3.45
I have the original gas tank out of my 86 Iroc, you pay shipping its yours... Just the tank, no gas cap, and no fuel pump.. .. Came from a TPI car. The tank did not leak, and I parted out the rest of the car, and sold the chassis, and just found the tank sitting in the corner of the garage today.
Email me at Screamer27@mchsi.com
Old Dec 15, 2003 | 12:44 AM
norcalz28's Avatar
If you can get me a quote on shipping I would be very interested. Please let me know. I appreciate it
Will
Old Dec 22, 2003 | 09:17 PM
Bwells92RS's Avatar
Car: 92 CAMARO RS
Engine: 305 TBI
Transmission: 700
That filler neck is covered by a recall. Check with your chevy dealer.
Old Dec 23, 2003 | 01:50 AM
norcalz28's Avatar
I read somewhere this was only true for 91??? Can anyone confirm? I might swing by my local dealer tomorrow
Will
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
