Cheap SuperRam?
Old Dec 22, 2003 | 01:18 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Cheap SuperRam?
What is missing from this that makes it so cheap?
http://www.jegs.com/cgi-bin/ncommerc...19&prmenbr=361
Lingenfelter's website makes this thing almost 5 times as much:
http://www.lingenfelter.com/lingenfe...=16&pf%5Fid=63
I am seriously confused
Thanks,
Old Dec 22, 2003 | 01:23 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
the one on the lingefelter site comes with all the stuff for a complete bolt on assembly:
wiring
sensors
throttle body
software w/ calmap
fuel pump
injectors
and some other stuff
Old Dec 22, 2003 | 03:00 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
So there's no getting around spending the $3k for an injection intake system for a large displacement "350"
I saw on lingenfelter's site what looks like an ACCEL version on TBI. I wonder what the net effect difference is?
Old Dec 22, 2003 | 03:20 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
If you have an L98 with TPI, you have everything needed for the Superram plenum/runners/base to work. The setup you are referring to is selling the harness, computer and everything needed for say, a bare engine without an ECU.
Same thing with the Stealthram. Holley sells the unity for around 2000.00 with all the stuff needed for an engine without management. If you got that stuff already, then the whole thing only cost about 800.00 to be ready to go!
Old Dec 22, 2003 | 03:40 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
I am starting from scratch. I have a 305 with a carb, so I have to get everything, I think.
Old Dec 22, 2003 | 08:47 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
No you don't have to settle for the SuperRam unless you need to stay emmissions legal (retain EGR). There is the Miniram, StealthRam, Ramjet, LT1 intake conversion, etc....
Converting to fuel injection doesn't have to cost $2000-3000 either. There are ways you can save alot on that cost. Here's a good "shoppers guide" on converting to TPI. If you'd rather not have TPI intake then just substitute it for your manifold or choice.
http://sethirdgen.org/tpi1.htm
Old Dec 22, 2003 | 10:25 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Also,
Accel, Edelbrock, and Holley make EFI conversions which include the intake manifold, fuel injectors, computer (which is tunable by you), O2 sensor, some other sensors, IAC, etc. for about $2,000 to $2,200 complete.
So you have alot to choose from!!!!!!
If I wanted to go to EFI and was converting from carb, I would seriously look into the above systems. This stuff is all at Summit Racing.
Old Dec 22, 2003 | 10:46 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Emissions legal is good
I'm not trying to make a trailer queen, so passing the sniffer is a part of my goals.
I just saw the Magnum TPI artcicles in GMTP. They are doing pretty much what I want to do. Too bad I don't live in pennsylvania. I guess that means I have to get the articles printed, point them andsay, "I want to do that".
Old Dec 23, 2003 | 01:06 AM
OMINOUS_87's Avatar
The Superram kit would be an excellent choice.
The Superram intake is proven and held with high regard in all performance circles. Not only is it polular here but a lot of Vette guys run it and you see it an awfull lot in magize featured ride spreads. It is polular in both factory fuel injection bolt on groups as well as those who are doing a carb to FI conversion.
The GEN 7 DFI that comes with it is top of the class. Other aftermarket fuel injection packages aspire to be rated on par with GEN 7 DFI.
And the price tag is reflective of what you are getting.
I run a Superram intake with my factory 165 ECM. My motor is modded pretty heavy and I am very pleased with the setup.
Old Dec 23, 2003 | 03:14 AM
Engine: 4.0L
Comparison of the Superram to the LT1 intake conversion as featured in the Aug issue of Popular Hot Rodding.
http://www.popularhotrodding.com/tech/0803phr_beast/
It shows that they are almost equal especially if you consider the LT1 is about half the cost.
I realize you need to pass the sniffer test so the Superram is your only choice.
Old Dec 23, 2003 | 03:16 AM
Engine: 4.0L
And the Gen 7 strives to equal the factory GM ECM.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Damon
Sep 26, 2015 04:29 PM
