Engine code question... help!!
Old Dec 17, 2003 | 03:32 PM
tjamison2001's Avatar
Car: 85 Iroc Z28
Engine: 305 V8 TPI
I hope someone can help me!?! I have an 85 Iroc V8 305 TPI that I've been doing some work on. My engine light has been coming on and throwing a code 34 (used the paperclip jumper method to get code). In the repair book it says the air sensor is bad. So got a Bosh loaner from a garage that I put in to test it out before I spent a couple hundred dollars on a new one. I unhooked the battery cable to reset the computer, put the other sensor on and drove the car for about 4 to 5 miles at 50 mph. I could feel the enging adjusting itself as I was driving. It seemed to smooth it out. At about mile 4 the engine light came on again.... *sigh*. Pulled the codes again and still got a code 34 again. Anyone have any suggestions on where to go to from here? I'm really at my wits end as to what else could be going on. Any info would be greatly appreciated!! Thanks.....
Old Dec 17, 2003 | 04:01 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Your ECU itself may be going bad. There are a lot of codes that include amongst primary troubleshooting guidelines "ECU may be faulty".
Old Dec 19, 2003 | 09:46 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
How do you check the ECU?
Old Dec 19, 2003 | 09:55 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
The '85 TPI used a one-off custom
box (MAS) to control power and burnoff
for the MAF sensor. They have been
known to go bad, yours sounds like
the burnoff may not be working.
If you can find another, try swapping
it in. (Check people that have done
the '85 to '86-'89 ECM swap to borrow
their '85 MAS)
http://www.eecis.udel.edu/~davis/z28...0FTMmodule.jpg
mike
Spyder_TheGamer
Dec 25, 2015 05:07 PM
happyhapka
Aug 15, 2015 04:42 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
