Planned Mods
Old Dec 14, 2003 | 03:45 PM
dongalonga's Avatar
Car: 1990 Chevy Camaro Iroc-Z
Planned Mods
Ok when I get back from the Army in August (leaving on the 31st) these are my plans for the car. I just want a nice street car that I can take to the track every once in a while. If you have any suggestions of anything else I should get let me know.
180 Thermostat
Tune-Up
Flush/Fill all fluids
New Tires 235-60-15 Dunlop GT Qualifier T/R
10 Spoke Camaro SS Wheels w/ Tires and Spacers(eventually)
Adjust Timing
T/B bypass
Gut Airbox
Remove A/C Compressor (everything else is done)
Front End Rebuild
Silverstars
Edelbrock TES (from ACS)
Accel 300+
Holley or Accel ADFP
Edelbrock Base/Runner
Ported Plenum
Holley 52mm T/B
Accel 24# Injectors
Accel EFI Fuel Pump (400hp)
S/R Torquer 305s
Crane CompuCam 2032
Comp Cams Chromemoly Roller Rockers 1.6 ratio
Sealed Power Pushrods 7.192"
Sealed Power Roller Lifters
Edelbrock Timing Chain Set
Summit Rebuild Kit w/Forged TRW Pistons(valve reliefs)
Exhaust Valve Reliefs Chamfered on Top Lip of Cylinder Walls
Fluid Damper Harmonic Balancer
Transmission Cooler
Richmond 3.42 Gears
Summit Racing Rear End Support Cover
Urethane Tranny Mount
Spohn SFC's
Spohn Steering Brace
Spohn Sway Bar Set
Spohn Torque Arm
Spohn Panhard Rod
Spohn LCA's
BMR STB
Weld Axle Tubes at Housing Junction
Drivetrain Direct 28 Spline Axles
Drivetrain Direct Solid Bearing Spacer
SLP Zexel Torsen Heavy Duty Differential
Hughes Transmission Overhaul Kit
Probuilt HD Sunshell
KYB GR2 Shocks/Struts
Old Dec 14, 2003 | 03:49 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
sounds like your on the right track
Old Dec 14, 2003 | 03:53 PM
dongalonga's Avatar
Do you think having TPIS port the plenum is wort it or should I get something like you have (Super Ram w/ Edelbrock Baseplate)? Also do you know of any descent street cam/valvetrain. I plan on maybe getting the 305 S/R Torquers when I decide to rebuild the motor.
Old Dec 14, 2003 | 04:02 PM
Car: 89 Formula 350
Lingenfelter doesn't recommend the super ram for 305's. having your plenum opened up is a good idea . you are going to want to get a better beathing base like the (edelbrock,big mouth or accel) or you could have your stock intake base ported. I've heard that the base is the most restrictive part of the TPI.
Old Dec 14, 2003 | 04:31 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
sounds good to me...yeah with the baseplate and runners just port the hell out of the plenum and ur good to go...the super ram is a no no...as far as a valvetrain, with new heads get all new crane or comp rockers, lifters, rods, timing chain, etc and do some research on cams...im gonna have a similar setup to what ur doin and i got the LT4 cam...with 1.5 rockers its 203/210 .445/.450 115 LSA...should work out well...have fun
dongalonga's Avatar
Actually I was thinking. Should I just send the T/B, Plenum, Runners, and Base out to TPIS so they can port and port match everything? I really just do not feel comfortable doing all of this myself because if i screw anything up I can't afford new parts. How much do you think it would cost to do all the port work? Yeah I think when the time coms (the motor is a reman that is less than 2 years old) I will call up crane or comp cams and have them set me up with everything.
Old Dec 14, 2003 | 04:33 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
ur better off with an aftermarket base and runners...it will get u more power than the stock stuff is capable of and wont cost u much more...very worth it...as far as the plenum u can do easily urself, its pretty screw up free...and if somehow u do screw it up, then buy one...or go to a junk yard and try again...the most important thing is research, take ur time and look around, learn how to do stuff and ull end up saving cash and having a better car...not to mention more fun...i see ur from MA eh? down the road...www.nefbody.com
Old Dec 14, 2003 | 04:38 PM
dongalonga's Avatar
So from what I have read all you really need to do is remove some EGR plates and open up the runner ports a little. I would imagine that the gaskets would let me get an idea of how much to remove on the plenum anyways right? Actually, that leads me to another question. Does the Edelbrock base/runners come with the installation kit?
Old Dec 14, 2003 | 04:41 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
the only things for installation are gaskets and if u want, intake bolts, which arent included...yeah somewhere in the tech articles is a great porting article, read it carefully and ull have no problems, knocking down the EGR wall and gasket matching the runners, and just try and get some more room so the air can get to the runners asap...
Old Dec 14, 2003 | 04:49 PM
dongalonga's Avatar
Oh ok I wasn't sure if they came with the gaskets, because it didn't say in summit. I can't seem to find the tech article on the plenum porting. All I found was how to do the runners and base in the tech section. If you could post a link it would be most appreciated. Thanks guys.
Old Dec 14, 2003 | 04:59 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
http://216.121.161.76/files/PlenumPorting.pdf
...it was in the index/FAQ for the tpi board in a sticky, check it out for other fun activities...
NEW ENGLAND F-BODY ASSOCIATION
Old Dec 19, 2003 | 11:20 PM
dongalonga's Avatar
Ok I have made some updates to the list I think that this will probably be it unless anyone has any other suggestions. Like I said this is a mostly street car that I want to be able to have fun in.
ZZ3Astro
Aug 13, 2019 12:57 AM
mfp189
Sep 27, 2015 09:25 AM
R13_Braz
Sep 18, 2015 05:00 PM
