255lph fuel pump require different fuel pressure regulator?
Old Dec 18, 2003 | 07:33 PM
TheFleshRocket's Avatar
Car: '89 Forumula 350
Engine: TPI 350
I need to replace the fuel pump on my '89 Formula 350. It doesn't seem like an aftermarket 255lph pump will cost much more than a generic factory replacement, and it couldn't hurt to have better fuel pressure potential down the road in case I end up modding the motor.
The motor is currently stock, aside from SLP headers.
However, I am concerned as to whether or not I will need a different fuel pressure regulator. Will the existing OEM fuel pressure regulator still supply the right fuel pressure to the motor even though 255lph fuel pump supplies fuel at a greater rate than the factory fuel pump would?
Or, will I need an aftermarket fuel pressure regulator to keep fuel pressure down to acceptable levels?
Old Dec 19, 2003 | 08:34 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I got a walbro 255 and my fuel pressure stayed the same as stock. I wouldent worry about it adversely affecting performance but an adjustable regulator is a good buy in and of itself.
Old Dec 19, 2003 | 08:38 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ive never heard of anyone having that problem, so i wouldnt worry about it.
Old Dec 19, 2003 | 03:33 PM
Guest
Guest
Posts: n/a
The 255 is volume. The fuel pressure regulator doesnt care about the volume of fuel, only the pressure... so there's no problem.
Old Dec 19, 2003 | 03:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
thats not 100% true.
the needle is going to be farther off the seat to maintain the same pressure...... its just that you'll need like a 800lph pump before a problem even starts to happen
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
