ty/sy ecm pinouts anyone?
Old Dec 21, 2003 | 06:01 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I found several on here but, nothing complete does any one have one? I have the ecm, 2bar map and when I do the swap in the spring I will be using a S/C with a boost bypass valve I bought from work. (way cheaper than what powerdyne and vortech want) my plan is to use ecm to control the boost untill I hit a decided MPH. the ecm is already made to work like that but, I need the wiring to do it
Old Dec 22, 2003 | 02:30 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Have you been here?
http://www.speedtoys.com/~bort62/7749/Main.htm
Old Dec 24, 2003 | 01:33 PM
Engine: ls1, LB9
I checked it out but, still nothing just the same stuff we have in the 749 swap page
Old Dec 24, 2003 | 03:52 PM
Engine: 4.0L
Then go here:
http://www.diy-efi.org/gmecm/ecm_info/1227749/
There are 6 pages of prints at the links on the bottom of the page.
Old Dec 24, 2003 | 06:41 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I'm confused as to what you're trying to get. Bort's page has all the neccesary repinning to get to the 749 from the 730. Are you trying to find the pinout to get from the 165 to the 730?
Old Dec 24, 2003 | 10:14 PM
Engine: ls1, LB9
they don't show the wiring for the boost control.
bassically it will keep it from making boost untill I am really moving and can use the added power
John Millican, thanks thats just what I need.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
