LT1 intake guys, please come in.
Old Dec 26, 2003 | 06:06 PM
87GTA Runner's Avatar
Car: 87 GTA
I ordered the LT4 hotcam today, got a good deal, my brother works at a Chevy dealer. This cam will go along with the Trick Flow 23* heads and 1.6 RRs I already have to put on. My plan is to go with a converted LT1 intake. I now heard on another forum here that this intake and all the associated wiring and everything looks like a rats nest when completed. I want it to look pretty good under the hood to go along with the performance. I have some $ invested in under the hood show parts, so I like to show them off, too. Anyone have some pics of your LT1 intakes installed neatly and looking good? How about the performance aspect? And finally, how does the setup I'm going with sound to some of you with more experience than me. Any and all opinions or thoughts would be greatly appreciated.
Old Dec 26, 2003 | 07:59 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Sounds like a pretty good combo. I'm running the LT1 intake along with ported 180cc Iron Eagles and an XE262 cam. It seems to pull pretty well, but definatly needs some more tuning. Since you can't hide the wiring under the plenum anymore it does seem to be more of a mess, but so far I've taken some time and done some cutting and soldering of the wires to clean it up a bit. Theres still a bit that needs to be done however. My setup is a swap into a G-body, so the wiring may look a little different than the factory setup.
Old Dec 26, 2003 | 08:16 PM
Car: 87 GTA
Do you have any pics? I would love to see it. I'm sort of an Olds man, too. I have an 80 Cutlass for a daily driver.
Old Dec 26, 2003 | 09:27 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Re: LT1 intake guys, please come in.
Originally posted by 87GTA Runner
............. I now heard on another forum here that this intake and all the associated wiring and everything looks like a rats nest when completed............
The wiring is only as good as it was before the conversion. The only wires that have to change are the CTS sensor re-location. No other changes are required wiring wise.
I have lots of pictures on my site of the completed swap.
Old Dec 26, 2003 | 09:34 PM
Car: 87 GTA
I was waiting for you to chime in John. I've been asking you the questions the past couple weeks. I have the Trick Flows and the LT4 cam. I didn't really check out the pictures you're talking about, I'll have to do that. I'll probably be placing my order next week now that I've ordered my cam and I know which one I exactly have. Thanks for all your help.
Old Dec 26, 2003 | 10:20 PM
85TransAm406's Avatar
Car: 1985 Trans Am
I'm currently working on my conversion, having some problems with fitment right now, but john is workin on it with me. Here's a pic with it sitting on the top of the motor.
Old Dec 27, 2003 | 08:45 PM
Engine: 4.0L
Here's the latest full size picture I have of the engine compartment.
Old Dec 29, 2003 | 09:12 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
What sort of fitment problems are you having? I'm just getting started on my temporary LT1 swap engine (on the stand) and would love to know of any more problems people are having.
As far as making it look good, keep everything in looms and route the coolant hoses at the rear of the intake if possible. I just ordered my -an fittings this morning for mine to class it up a bit...
:lala:
Old Dec 29, 2003 | 11:11 AM
Car: 1985 Trans Am
I'm really only having a problem because i'm running sportsman II heads, and they have really large coolant passages, so the intake doesn't want to cover them up all the way. Most heads don't have a problem though. I'm also having a little problem with the bolt pattern that John drilled, but again, mainly because i'm running those heads. I'm having him send me one without the bolt pattern drilled so i can match it up exactly, there's not much room for error. My coolant passages are in the rear also, that's how John does all of them now. Looks neater IMO.
Old Dec 29, 2003 | 01:41 PM
Formula383's Avatar
Car: 88 Firebird Formula
I had the same problem w the Dart II heads. But all I did was take the manifold to a machine shop to have them add flanges and the problem was corrected. When I did this conversion I did not know I was going to have the problem with the manifold not being wide enoungh. Problem solved.
Old Dec 29, 2003 | 03:09 PM
Car: 87 GTA
Thanks for everyones help on this one. I received my hotcam from the dealer today, so I'm going to go ahead and order my LT1 intake from John.
Old Feb 29, 2004 | 10:30 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
heres my lt1 intake
Old Mar 1, 2004 | 01:17 AM
Engine: 4.0L
Originally posted by 383LT1intake
heres my lt1 intake
That is a very nice example!
Old Mar 1, 2004 | 08:06 AM
Car: 92 camaro
Engine: 383 stroker
thanks john and thanks for all your help this will be my 3rd year with the lt1 intake no probs with leaks or anything prob got 20-25000 miles on lt1 intake
Old Mar 1, 2004 | 10:01 AM
Car: 1985 Trans Am
You have any more pics, 383LT1intake? Maybe a link to your cardomain page if you have more there?
Old Mar 1, 2004 | 03:25 PM
Car: 92 camaro
Engine: 383 stroker
here i just added a few more pics
http://www.cardomain.com/memberpage/538314
Old Mar 1, 2004 | 07:52 PM
Car: 87 GTA
383 I have a couple questions for you. I want to get the radiator hose like you have, do you know off hand what length yours is? Second, what is the sensor that is right behind the TB, opposite side of the cables? Thanks.
Old Mar 1, 2004 | 09:28 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
MAP sensor
Old Mar 1, 2004 | 09:43 PM
Car: 92 camaro
Engine: 383 stroker
yeah its the map i swaped from maf to map last year also the hose length would depend on how far back you put remote houseing i have mine back as far as i can get it almost under brake master cylinder i bought mine from ebay they are wayy cheaper than jegs or summit look there first i think i bought the longest one im not sure if youd like ill measure it tomorrow
Old Mar 2, 2004 | 02:42 PM
Car: 87 GTA
Thanks. I'll be running MAF, so I guess I won't be needing that. Did anything else go there when you had MAF? It looks like something does need to go there. And what should I look under on ebay for the coolant hose? Thanks again.
Old Mar 2, 2004 | 04:28 PM
Car: 92 camaro
Engine: 383 stroker
what i did when i had maf is get a nice looking ss button head bolt put a little rtv around it and slide it in didnt look bad didnt see the rtv jus the head of bolt
look under stainless steel hose
heres one on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...category=33601
Old Apr 29, 2004 | 09:09 PM
KiLLJ0Y
Guest
Posts: n/a
is there any way that the LT1 intake can be made smog legal? i really want to do this conversion but im in Cali and i need EGR, could a custom adapter be made?
i was thinking an adapter with a 90* bend to the driverside so an EGR can be still used. any thoughts or ideas?
Old Apr 30, 2004 | 08:15 AM
Engine: 4.0L
It would be tough to make the LT1 intake conversion smog legal. In fact just because you rig an EGR valve to it doesn't mean it'll pass Calf smog.
Your idea about a 90° bend is fine but it would have to have two holes, the EGR valve itself has two holes.
Next you will need some way to route exhaust to the intake next to the EGR mount. This is because the LT1 ran external EGR, not internal like SBC's. The differance is in the heads.
Old Apr 30, 2004 | 11:34 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
In order to clean the engine compartment up on my modified LT4 intake, I bought some Corvette fuel rail covers. They are black plastic pieces that use four studs bolted to the intake to hold them in place. It covers the fuel rails, injectors and all the wiring down to the valve covers. It required some trimming of the back side of the pieces to clear the distributor and fuell lines but it looked much better.
Sadly, I have since totalled the car and am in the process of selling the whole thing. Luckily the motor is still ok but I never got a chance to get pics of it before the wreck. I have plenty of after pics but they are just too sad to post.
Old Apr 30, 2004 | 11:37 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
normally i am NOT a fan of any kind of covers.
but the corvette LT1 covers look nice
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
Thirim
Aug 9, 2015 06:19 PM
