Is a Knock Sensor only for an L98 block?
Old Dec 29, 2003 | 07:25 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I was reading TPI swappers guide over the weekend, and I was wondering if you need a certain block to use the knock sensor. My dads ZZ4 was swapped by someone else, and I remember seeing some sensor on the passenger side that had no wiring going to it.
Old Dec 29, 2003 | 07:29 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The knock sensor plugs the coolant drain plug so it will work on any SBC but you need to get specific sensor depending on weather you have a 350 or 305.
Old Dec 29, 2003 | 08:15 PM
blackroc68's Avatar
On my 1986 iroc with 383 i used my 305 knock sensor. isnt it the same as a 350.
Old Dec 29, 2003 | 10:44 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
no two different part#'s
Old Dec 30, 2003 | 06:47 PM
cbmotorsports's Avatar
Car: 1988 GTA
Engine: 5.7
knock sensor
Is there a way to bypass this sensor? Keep getting 43 code. Have it narrowed down to the sensor or module. Tried to switch the sensor and can't get it out. If there isn't any way to bypass, any hints?
Old Dec 30, 2003 | 07:58 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
cbmotorsports,
A code 43 is "Low voltage at electronic spark timing circuit" I would recommend checking all the connections before ditching your knock sensor; it could very well save your engine from disaster.
If still you want to bypass it put a 3.9k resistor between the sensor plug and ground if you are running a 730 (MAP) ECM. If you have a 165 (MAF) ECM you will need to use a 100k resistor. Or you can disable it in the PROM if you can burn chips.
9192camaro
16
Feb 3, 2019 12:21 AM
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
