Injectors needed
Old Jan 3, 2004 | 02:36 PM
Packy's Avatar
Injectors needed
Ok, guys I posted before the I had a problem with a misfire. Well, it turns out the number 1 and 6 plugs were alittle loose in the head. Fixed that still mis was there, we looked further, and came up with number 1 injector is bad.
My bro tells me to just change the 1 thats bad, but I rather change all at once. So, Im looking for replacement injectors.
Engine is stock as far as I know, it does have Hype chip, headers and flowmaster exhaust. What is a good inj. to get?
Thanx in advance, Jorge
Old Jan 3, 2004 | 03:19 PM
blackroc68's Avatar
i tell you 1 not to get( accell.) I only had used them for 6 months and 1 shorted out. i still have 7 good ones though.
Old Jan 3, 2004 | 03:51 PM
benz28's Avatar
Car: 87 Camaro Z28
Engine: 305 - 350 Swap
Transmission: 700-R4
cruzinperformance.com
If it can be rebuilt you can spend less than $100 and send them to www.cruzinperformance.com. I had my injectors rebuilt there and Rich is very helpful and sends you flow numbers and characteristics of your injectors before and after testing.
As for buying a whoe new set, I heard GM OEM parts is the way to go.
Old Jan 3, 2004 | 07:16 PM
Packy's Avatar
thanx for info. and that link doesnt work.
Now the only thing is, I cant send in my inj. I need to car to get around still
Old Jan 3, 2004 | 09:29 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
OEM GM injectors are at least $90 each, meaning that a new set is going to be $720!
The cheapest aftermarket option I found was Ford SVO injectors. I used 24 lbs/hr ones in my 350. A 305 would use 19 lbs/hr ones. You will need to get a custom chip burned to revise the fuel tables for the new injectors too. Summit sells the injectors for $200-$225 a set depending on the size. Then you need to find someone familiar with the setup that can burn you a chip. TPIS did mine and lit works like a charm.
Old Jan 4, 2004 | 09:40 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I have stock 19 and 22 pound injectors if you're looking to piece something together.
IROCZ1989
Jan 24, 2016 03:55 PM
ezobens
Aug 19, 2015 10:29 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
