Fastest NA TPI
Old Jan 4, 2004 | 11:39 PM
gruveb's Avatar
Car: 1989 IROC-1
Fastest NA TPI
Who has the fastest naturally aspirated TPI?
Old Jan 5, 2004 | 06:55 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
These are all 350's ... no bigger cube motors in the following results.
I've seen Mike Davis go 11.9's with an upgraded TPI setup (AS&M runners, ported and siamesed Edelbrock base, AFRs, LT4 HOT Cam, etc.).
I've seen him go 11.8's with the Holley Stealth Ram.
I've gone 11.6's with the MiniRam.
The above results are definitely not a direct comparison though. Our setups are different. I have no doubt that Mike could run faster than 11.6's if he had my heads, cam, and a MiniRam. He just puts down awesome times!
Tim
Old Jan 5, 2004 | 08:44 AM
gruveb's Avatar
Car: 1989 IROC-1
Tim
Thanks.
Thanks Tim. And you have worked AFR heads?
Old Jan 5, 2004 | 01:40 PM
TRAXION's Avatar
Originally posted by gruveb
Thanks.
No problem ... and yes, they have some work to them - nothing huge, but enough to give me about 15cfm more than box stock.
Tim
Old Jan 6, 2004 | 12:59 PM
gruveb's Avatar
Car: 1989 IROC-1
What about guys that aren't running mini ram/super ram/stealth rams?
Just out of curiosity.
Old Jan 6, 2004 | 01:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you mean untouched stock TPI stuff?
i donno, but its SLOW.
Old Jan 6, 2004 | 01:53 PM
gruveb's Avatar
Car: 1989 IROC-1
No, afermarket runners, maybe new base...
Old Jan 6, 2004 | 04:26 PM
kevinc's Avatar
Car: 1982 Z28
I ran 13.2 @ 102 with HOT cam, aftermarket base, hogged out stock runners and plenum.
Old Jan 6, 2004 | 04:37 PM
llvll4l2c91350's Avatar
stock heads?
Old Jan 6, 2004 | 04:47 PM
kevinc's Avatar
Car: 1982 Z28
ZZ4 heads unmodified.
Old Jan 6, 2004 | 05:24 PM
zerotosixtyV8's Avatar
Car: Camaro
those are the same as vette heads? that's still not bad for a 66.666% stock motor (cam is a third of the big three modifiers, intake, heads, cam). where you running an aftermarket stall and rear or where you a manual?
Old Jan 6, 2004 | 06:27 PM
kevinc's Avatar
Car: 1982 Z28
ZZ4 heads use the same casting as Vette L98 heads, just with better valvetrain hardware (hollow-stem LT4 valves).
It wasn't totally stock shortblock, I had the crank ground -0.010" and block bored +0.030". Nothing fancy, just a set of hypereutectic flat-top pistons.
Trans at the time was a TH700R-4 with Vigilante 2600-2800 stall converter, 3.42 gears, Edelbrock headers, Random cat.
It passed NJ treadmill emission inspection on the same PROM, which was nice.
Old Jan 6, 2004 | 08:10 PM
Car: Camaro
that's a great time for a more or less stock headed L98!
Old Jan 7, 2004 | 11:56 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I ran a 7.77 TPI 1/8
mods
AFR
10.4/1 comp
xtreme grind
3.73
3200 Coan.
Edelbrock base
SLP runners
stock ported TB
switched to a SR and ran 7.60/12.00 no tuning, but man is it a pain
Chris(car will still not idle!!!)
Old Jan 7, 2004 | 01:09 PM
jrleflin's Avatar
Car: 87 iroc
Engine: 383
At this site: http://temp.corvetteforum.net/c4/beach_bum/
go to the proven set-ups section.
Some fast superram, miniram and long tube runner motors with a couple of LT-1's mixed in I think. I think they're all streetable. They are Corvettes though, but still the same motors.
there outa be a vote on the best one at that page.
Old Jan 12, 2004 | 06:06 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
those times prove my point even more:attention to detail is the only solution!
Old Jan 15, 2004 | 11:36 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
How about stock TPI stuff, no aftermarket base or runners, just stock with any amount of porting?
Old Jan 17, 2004 | 05:56 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
My son's car (Kevin91Z) with Corvette heads, ZZ4 cam, and stock port-matched TPI went 13.23 @ 107.19 with a 1.98 60' time. I know there are better ones out there.
Old Jan 18, 2004 | 01:24 AM
Car: Camaro
107 MPH is practically a 12 second trap speed. what kind of tires was he running?
Old Jan 18, 2004 | 10:21 PM
Car: 92Z28
Transmission: A4
Nice MPH! wow I think he could have ran 12s easy with some tire under it. Ive seen cars run 12s with 103mph trap speed. I'm hoping to eek out a 12.9*** with mine. We'll see soon. The strip opens in February
BTW, I love his car (Kevin91z). I would not have modded mine if I wasn't inspired by his.
Take care,
Charlie
Old Jan 25, 2004 | 05:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I am running 12's now, but I added an LT4 HOT cam, and SLP 1 3/4" headers instead of 1 5/8".
I was also using BFG Drag Radials but am now using M/T ET Streets.
Old Jan 27, 2004 | 08:54 AM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
What do you mean when you say "it is a pain". You mean the tuning or the installation? I haven't installed my SuperRam yet and wanna be mind prepared.
Old Oct 31, 2004 | 11:49 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
305 TPI, 5-speed
TPIS intake parts
Daily driver, emissions-legal
12.9
Tim Burgess
Electronics Board Moderator
Old Oct 31, 2004 | 12:55 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I can't seem to get that page to come up
Old Oct 31, 2004 | 01:02 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Originally posted by Willie
305 TPI, 5-speed
TPIS intake parts
12.9
Tim Burgess
????? what cam , heads , etc . Is this N/A ? I don;t expect much less than 13.8 with mine . But it all could be where in the world we are both from ( elevation) .
...I too cannnot make that link open . I would like to see it
Old Oct 31, 2004 | 01:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
last i heard, willie is supercharged.
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
The thread (and link) is 8 months old, so it could've changed since posted, though I'd like to see it as well
Old Oct 31, 2004 | 01:46 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
i'm trying to see how fast i can go with the stock cam/heads(boltons listed in sig). MY best to date is a 13.21@104.6. The only other external engine bolton I plan on is an Alumium DS. After that I'm going to build a new engine with the 219/219 cam and AFR 195 heads. I will be hoping to run low 12's high 11's after I build that setup...
Old Nov 1, 2004 | 02:33 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
yah i woudl love to see what is up with Tim's 305. i heard it was N/A and in the 12s which blows my mind. Willie, do you or anyone else have any info on this before we all PM him LOL
Old Nov 2, 2004 | 07:35 PM
DSM's Avatar
DSM
Car: 84 Z28
Axle/Gears: 3.73 Torsen
84 Z28, T5 and 3.42s. Two weeks ago went 13.21 @ 104.45 on a 1.905 60-foot. Combo:
350, stock 89 GM shortblock
Vette aluminum heads, machined for springs but otherwise stock
STOCK runners, STOCK base, STOCK 48mm throttle body
STOCK MAF with screens in place, STOCK 22 lb Rochestor injectors
plenum ported to remove EGR bump
air boxes cut, no filters (track only of course)
Edelbrock TES, test pipe, 3" I-pipe and Ultraflow muffler
cam: custom roller 207/213 @ .050, .476 lift
stock 1.5 stamped rockers
el cheapo underdrive crank pulley, no smog pump
race weight with driver 3520 lbs
Holley AFPR, but its set for 41 psi/no vacuum and it still runs 11.8-12.0 A/F at WOT.
In September it went 13.37 @ 103.45 with 60-foots in the low 1.80s. Track prep wasn't as good this last time out and I struggled to get 1.90s. With the traction I had in September, the car would have gone 13 teens. FWIW, the only changes between the 13.37 and 13.21 runs were the underdrive crank pulley and a poly torque arm mount to replace my wasted stock one. With a fresh set of DRs and some weight reduction over the winter I'm shooting for 12.99 in the spring on the existing combo.
Not to knock anyone elses efforts, but I see quite a few people here who have spent a lot of money and thrown a lot of parts at their motors to go slower. My first time out in the car this year I was running 13.90s at 99. Since then I put over 50 passes on it (and no, I haven't broken the stock T5 yet) and kept detailed logs of my tuning. Other than a new cat-back and the underdrive pulley, I really haven't touched the motor this year at all.
My combo may not make for an exciting message board sig, but it seems to work!
Old Nov 5, 2004 | 10:35 AM
racingdragracer's Avatar
Car: 1969 camaro
Engine: 90 TPI
Transmission: 400turbo
Stock TPI
I have a 69 camaro with a stock 86 TPI. 3400# car. 11to1 compression on 93 octane. Edelbrock heads.
1.60 60 ft
7.84 1/8 mile
12.64 1/4 mile
109 mph
Old Nov 5, 2004 | 11:39 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
can you list some specs on your motor racingdragracer
Old Nov 7, 2004 | 06:07 PM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
Axle/Gears: D44 3.33 gears
I'm not sure if this comparing apples to oranges, but I know of several L98 Vettes that are running deep into the 12s on stock heads/cam NA. My 91 has gone 12.73 at 106. I have an accel base, ASM runners, ported plenum, 1.6 RRs, 2500 stall converter, Hooker long tubes and 2.5" exhaust. I have some other minor bolt-ons (low temp fan switch, 160 stat, etc), but the car is NA and has stock heads/cam.
Old Nov 7, 2004 | 10:03 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I just went 13.39 @ 101.8 this past weekend w/ completely stock TPI setup, stock exhaust manifolds on a 355 w/ TFS heads and 227/233 cam. The car is overcammed big time for this intake though. W/ headers and a converter, I think the car can see 12.7 12.8s though...
bjpotter
Jan 22, 2019 12:27 PM
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
