EGR Valve Prob
Old Jan 5, 2004 | 02:28 PM
mrtransams's Avatar
Car: 91 firebird - 81 TA
Engine: 305- 400
Transmission: 5 speed
EGR Valve Prob
I just replaced the EGR valve because I was getting a code 32 error _ dash light
Now the rpms JUMPS up and down
Like 1 grand then 1.2 back and forth
It stops when the car warms up or if I pull the EGR valve hose off what’s going on and now I still get the check engine light
After I have been driving 30 min
91 firebird 305 tpi
thanks for your help
Old Jan 5, 2004 | 09:13 PM
benz28's Avatar
Car: 87 Camaro Z28
Engine: 305 - 350 Swap
Transmission: 700-R4
EGR solenoid
What was happening before when you had a code 32? Did your car search for an idle before you replaced the EGR valve?
When you pulled the EGR hose off, did you feel if there was a vacuum when it's in park?
Check the EGR solenoid if it's producing vacuum with the car in drive and you are raising the RPMS around 1500-2000. There should be around 10inHg vacuum around these RPMs. There is a nice diagnostics page for PWM EGR valves here:
https://www.thirdgen.org/techbb2/sho...egr+diagnostic
Old Jan 5, 2004 | 11:03 PM
mrtransams's Avatar
Engine: 305- 400
hmmm
well I replaced the egr valve becouse the engen light would come on after 30 min of driveing I checked the computer and got a code 32
I have not rechecked the codes yet
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
