Bogging problem
Old Jan 5, 2004 | 02:34 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
Bogging problem
Ok, heres my question.
What would cause a car to bog at 3000 rpm and up? When it hits 3000 rpm, it stumbles and makes some popping noises in the intake and in the exhaust (sounds like it anyway) like its got too much advance in the timing. My timing is set to 6 degrees base, timing wire is plugged in and the car didn't start doing it until I pulled the motor to swap cranks.
All of the ignition system is less than 2 months old.
Other than the bog, the car runs good. Runs pretty smooth down low for having a cam.
Here's the specs for the motor:
350 w/ WP Sportsman II heads
Holley Stealth Ram w/ stock TB
24 lb SVO injectors
Summit 1103 cam (214/224 lift, .47x lift, 112 lsa, and 1.52 Comp Cam rollers)
Thanks for the help.
PS. already changed the fuel filter. Also put ANOTHER set of plugs and wires on it too. Dont think its fuel due to before the crank swap, it ran like a raped ape.
Old Jan 7, 2004 | 02:22 PM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
How old is the fuel filter?
Old Jan 7, 2004 | 02:38 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
how did you adjust the valves?
db057
Apr 28, 2019 07:45 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
