Cleaning The inside of my plenum
Old Jan 6, 2004 | 08:22 AM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
Well I have mine off to polish it and found a lot of black stuff build up inside, And am wondering how do you clean it out and will it make a diff in performance?
Old Jan 6, 2004 | 08:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
id just spray some carb or brake cleaner around in there..
wont make any real diff in performance, but atleast you know it'll be clean...
Old Jan 6, 2004 | 03:32 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
i took my intake, runners and plenum off and sandblasted everything inside and out, then ported everything, and powdercoated my intake and polished the runners and plenum. It looks real good after all the work and im hoping to see a bit of performance gains as well. But i would sandblast everything inside and out, makes it nice and clean!
Old Jan 6, 2004 | 11:05 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
MrDude_1's right, carb cleaner should work well. I let the runners and plenum sit in the parts cleaner for a while but it stained the plenum - it was clean though! I painted the plenum and runners anyway.
Old Jan 6, 2004 | 11:21 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Pick up a big Rebbuermaid heavy duty bin at Target that is big enough to hold the plenum lying down. Then get 3 gallons of carb cleaner (the nasty stuff in the cans) and soak the plenum in it for 24 hours. A little work with a stiff bristled brsuh on the inside will remove all traces of the oil sludge.
I wouldn't recommed sand blasting. If any sand is left inside, and it invariably is, and it gets into the engien it can do some serious damage to the pistons, ring, bearings, and valves. Just not worth the risk in my opinion.
Old Jan 7, 2004 | 06:51 AM
ss85tadude's Avatar
Car: 85 Trans Am
So by cleaning it out it won't make a diff in air flow? Right now I have the sides polished and I don't want to damage the polished parts. What about none of those long 1' cone shapes brushes like youi would use for wheels (sorry I don't know what they are called)?
Old Jan 7, 2004 | 10:54 AM
It may make a minor difference in measured airflow, but I don't think you will notice any power increase. I did this to both the upper an lower manifolds in my old 5.0 Mustang, and it made no noticeable difference. It made me feel better though.
The carb cleaner won't hurt the polishing either. Just thoroughly rinse it with water and dish soap and dry it with compressed air. Oh, and don't get any of the carb cleaner on your skin. It burns, it burns!
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
lakeffect2
Sep 7, 2015 03:52 PM
