marine camshaft?
Old Jan 21, 2004 | 10:18 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
marine camshaft?
Hi all
Old Jan 21, 2004 | 01:06 PM
Guest
Guest
Posts: n/a
Make sure its for a standard rotation engine before you think about ordering it.
Old Jan 21, 2004 | 01:42 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Old Jan 22, 2004 | 08:57 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Ok
Old Jan 25, 2004 | 08:20 AM
Bowtie67's Avatar
Car: 67 Chevy, 2000 Pontaic GTP
Engine: 415SBC Holley Stealth Ram
Marine Cams, In 85 - 86 Ford used marine cams, at that time most cams in stock cars were lowend cams and fuel economy, marine cams have stronger midrange torque. which is where a lot of cars fell off, get off the line then performance was basically void, Automanufactures only wanted to get cars off the line and operate only at the cruise RPM, this is where they felt was the most important. Marine cams are meant for the power band in the middle not the end, most boats don't run full out when their on the lakes, there cruising in the middle of their RPM band for pulling skiers or getting across the lake. In a car most people are not running full out except in a drag race, so how often does someone tach out a motor on the street? lowend more midrange is more street than topend. I to have opted for a marine cam in my new 414SBC chevy, ON DD2000 it is showing over 400TQ at 2000 RPM and a peak TQ of 530 @ 4500RPM with peak HP @ 5500, how often will I see this PK, not real often unless I want to draw a lot of attention...
Old Jan 25, 2004 | 09:06 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
thanks ,
69GTOby
Apr 18, 2016 02:34 PM
GTAman
Sep 26, 2015 02:01 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 21, 2015 10:24 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
