Code 32: EGR
Old Jan 26, 2004 | 09:06 PM
profiveo's Avatar
Car: 1992 Camaro Z28
Engine: 350 L98
Code 32: EGR
Hey guys, my check engine light has been coming on recently. I finally checked out my codes and got a code 32. Where should I start for this problem?
Old Jan 27, 2004 | 12:23 PM
Rob91GTA's Avatar
Car: 91 GTA
Engine: 5.0 TPI LB9
Transmission: 700R4 Auto
I had the same problem. Turned out to be the vacuum line going from the throttle body to the EGR was melted. So check your vacuum lines first. If your vacuum lines are okay it could be a bad EGR valve or maybe even the EGR solonoid. Post back and let us know how you make out.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
djmarch
Oct 2, 2015 10:41 PM
indygene
Sep 26, 2015 11:21 AM
Lmancha96
Sep 25, 2015 08:11 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
