What kind of valve cover gaskets do you recomend?Rubber,cork,etc.....?
Old Jan 26, 2004 | 07:49 PM
TPI86TA's Avatar
Car: 88 GTA
What kind of valve cover gaskets do you recomend?Rubber,cork,etc.....? I need to get some for my Trans Am...Thanks, Al in NJ
Old Jan 26, 2004 | 08:32 PM
OMINOUS_87's Avatar
Not cork.
I will be ditching my double thick cork for some molded/crushless rubber ones and RTV in the bolt holes.
Expensive option at 40$/pair but corl leaks.
This is on perimiter bolt covers, centerbolt are much better controlling leaks.
Old Jan 27, 2004 | 12:39 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: What kind of valve cover gaskets do you recomend?Rubber,cork,etc.....?
Didnt you post this in another category? Hmmm. Think I answered this under tech engine thread.
Old Jan 27, 2004 | 08:09 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yea, i already answered you in the other thread too...
try not to post the same question more then once on the board.
Old Jan 27, 2004 | 02:04 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Rubber with the steel frame in the center. They don't leak and they last forever.
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
