Custom ram air camaro boxes
Old Jan 31, 2004 | 02:55 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I saw these on Ebay. Anyone buy these before?
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
Old Jan 31, 2004 | 08:02 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I got a set of those...some others on this board have gotten them too..
Old Jan 31, 2004 | 08:04 PM
another
Old Jan 31, 2004 | 08:05 PM
one more, these are actually his first design set but just about the same....they used to be cheaper too...he's gone up $20...I like them!...it takes alot to get them in correctly, you have to cut the bottom of your air boxes if you want them to be sealed all the way thru.
Old Jan 31, 2004 | 11:16 PM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
That guy that sells those boxes is a stroke, any gear head with minimal metal working experience can make those boxes, for less than 20$ with rivets to fasten them, seeming can be done too for little extra work. If you removed the baffles(see attached photo) and use K&N's your going to see a dramatic improvement in airflow.
Attached Thumbnails Custom ram air camaro boxes-air-cleaner-base-lid
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
