Wont start, backfires and so on...
Old Feb 7, 2004 | 02:06 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
A friend of mine has this problem on his 350TPI -90.
Background: Driving around and car starts to missfire, stops open the hood and sees sparks between distributor and ign.coil. Tries to drive home but it only gets worse.....then it dies..
Now the car wont start, it has spark but only backfires when trying to start......
Checked and changed:
Camchain (new)
Distibutor (new)
ign.module (new)
ign.wires (new)
plugs (new)
How exactly is the timing controlled when you crank the engine?
I know it changes over 400rpm
Old Feb 7, 2004 | 07:28 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Check your pickup coil.
Old Feb 7, 2004 | 08:49 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
It sounds like either your coil isn't grounded or it is bad. It is cheap replace it.
Old Feb 9, 2004 | 11:49 AM
87camaroz28310's Avatar
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
do you have hei or external coil because with external you dont even have to have the coil bolted down for it to work it just sound like you have a cracked cap or it's just the wires arcing
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
