TPS adjustment
Old Feb 9, 2004 | 02:47 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
TPS adjustment
when i am adjusting my TPS what two wires do i use to get the voltage reading on my meter
Old Feb 10, 2004 | 12:43 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
The top two. Negative on top and then positive underneath it (which is the middle wire on tps).
Old Feb 10, 2004 | 08:52 AM
ULTM8Z's Avatar
It's the blue and black wires you need to probe.
Old Jun 8, 2004 | 10:16 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
TTT i got what wires i need to test but what exactly do i need to do to adjust this? also, what should it be reading?
Old Jun 8, 2004 | 01:47 PM
ULTM8Z's Avatar
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Most people's questions have been answered before and are documented in the techinal articles section.
Old Jun 9, 2004 | 12:31 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
very nice i just figured i would post a question while i was searching. just a little later on i found the same exact thing you posted!!! thanks for the link tho
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
