Schrader valve for HSR not same as TPI! Need correct part!
Car: 1990 IROC-Z 350Stealthram 11.61@120
Engine: 350 Stock Bore&Stroke
Transmission: 700R4 Auto/Vigilante 2600
Axle/Gears: 3.42 Stock 10 bolt
I took my schrader valve off of my TPI fuel rails to install it on my HSR in order to check my fuel pressure but it doesn't fit. The TPI valve has coarse threads and the HSR has fine. Does anyone know the Napa part for this? I have a hypertech fuel pressure gauge that I used on my TPI and want to keep using it to check my HSR.
If anyone has a part number for this please let me know.
Thanks,
Pablo.
Thanks,
Pablo.
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
The threads in the HSR rails are 1/8" NPT, and I assume the Hypertech gauge is a -4AN.
Just use a straight -4AN to 1/8" NPT adapter, Aeroquip part # AER-FCM2001.
$2.95 from Summit.
$2.95 from Summit.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
$2.95 from Summit.
$2.95 from Summit.
How much?
Originally posted by CaptPicardsZ28
What he said. I ordered mine from GRAINGER. I ordered them through the place I work. They wont sell to general public. If you need one I have extra. I can mail you one of mine. Go to stealthram.com and check out their boards. This question was already raised. Also, click on their parts list and scroll down and read about it.
Please let me know.
email me to : pablo.ledezma@lmco.com
Originally posted by 86WS6_T/A
hmm, my HSR's fuel rails came with a schrader valve..
Re: >
Originally posted by chevyengr
They sure did! If you are running the NOS kit for TPI, you know you need to get the right schrader valve if you want to keep the system on your new HSR. Also, the hypertech fuel pressure gauge will not work on the HSR valve.
R3500
08-17-2015 12:16 PM
Sanjay
08-12-2015 03:41 PM
