LTI head ?
Old Feb 11, 2004 | 12:19 PM
sillyiroc's Avatar
Car: 89 Iroc
Engine: 350 vortec TPI
Transmission: 95 T56
LTI head ?
A budy of mine told me he has a set of Lti heads he will sell me that were converted to use a vortec manifold. I have not seen the heads yet but I will soon, is this possible? I was planning on buying vortecs but this would cost me less. Do the Lti heads flow as good as vortecs? If this would work would it be a good idea?
Old Feb 12, 2004 | 08:33 AM
CScheip92's Avatar
Car: 1992 Camaro RS
Engine: LO3
Never heard of something like that. I know they can be modified for a typical SBC intake but for a Vortec style? The two bolt patterns are immensely different. I'm going to have to call
Old Feb 12, 2004 | 08:48 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It could be done. You would have to convert the heads as normal for a SBC then re-drill the head for the Vortec intake bolt pattern.
It would be very much more cost effictive to use a LT1 intake with LT1 heads. half your work is done right away since the intake bolt patters are an exact match. If you are carbed then that's a different story.
Old Feb 12, 2004 | 12:19 PM
sillyiroc's Avatar
Car: 89 Iroc
I am already LTR and would like to stick with it. He claims they were drilled for the vortec manifold, and the water holes welded and the heads decked. I alread have the SD vortec manifold but will these heads flow as well as the vortecs? Im looking on building a 12 sec motor.
Old Feb 13, 2004 | 11:52 AM
sillyiroc's Avatar
Car: 89 Iroc
Wich head flows more LTI or vortecs?
Old Feb 13, 2004 | 12:05 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Vortecs flow better than any production head, other than the LS1. The low lift flow numbers are particularly impressive.
I don't see how LT1 heads could be modified to work with a Vortec intake. The Vortec heads have raised ports, not just a different bolt pattern. The LT1s can be modified to work on a traditional small block, but I wouldn't bother. If you want to run a Vortec intake use the Vortec heads modified for a high lift cam. That's the most cost effective solution, and there are plenty of guys running 12s with that setup.
Old Feb 13, 2004 | 01:23 PM
sillyiroc's Avatar
Car: 89 Iroc
yea it looks like it might be a wast of time. I am going to look at them and see if its for real.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
