all 383 guy's with tpi what are you running? cam,intake,headst
Old Feb 15, 2004 | 10:51 PM
i8a4re's Avatar
Car: 89 iroc-z
Engine: 350 tpi, 91 vette
if you have a 383 please list what cam, heads, and also if you retained the factory tpi setup with porting or what, and your results. thanks
Old Feb 16, 2004 | 01:30 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I'm running a LT1 intake, stock ported L98 cast iron heads w/ stock valves, LT4 Hotcam, and edelbrock headers. Just have to get some track times.
Old Feb 16, 2004 | 02:34 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm running Dart Sportsman II iron heads at 10.5:1 and a custom Comp Cam with .495/.502 lift, 218/224 duration @.050, and a 112 LSA and a Lingenfelter/Accel Super Ram with a custom chip.
Or I should say I will be --- right now it's all on an engine stand in my garage waiting for a buddy to be available to help me install it.
:lala:
Old Feb 16, 2004 | 11:40 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I think he means to keep the stock TPI setup. If that is the case you must do all the porting possible. Port match every transition (throttle body to plenum, plenum to runners, runners to base, base to heads), port out the plenum and port the base but do not siamese it.
Pick a cam that provides idle to 5,000rpm because you won't be breathing past that
Old Feb 17, 2004 | 12:20 AM
i8a4re's Avatar
Car: 89 iroc-z
well that answers it for me but why not siamese it?
Old Feb 17, 2004 | 12:28 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
There is a risk of starving cylinders. Some ppl get away with it, but the scary thing is you won't know it is happening and your engine dies within months. I would not do it. FWIW, you can pick up an aftermarket base on ebay for a good price and port the hell out of it and it will flow more than a fully siamesed stock base.
Yeah tho, thats the major point - you could hurt your engine
Old Feb 17, 2004 | 09:30 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
TF Heads to about 10:5:1 Comp, LPE 219 cam, and a superram ported to the gills.
Fast355
Dec 2, 2016 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
86IROC112
Aug 17, 2015 02:00 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
squiggy2
Aug 9, 2015 09:30 PM
