Lots of vacuum preasure in gas tank, Why is this?? do I need new charcoal filter?
Old Feb 17, 2004 | 03:39 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
Title pretty much says it all.
Old Feb 17, 2004 | 04:33 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Probably. Sounds like the tank can't vent, so that would be a good place to start.
Old Feb 17, 2004 | 04:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is another plastic vent coming off the fuel tank and is located on the car frame near the left rear tire. Also, are you using a vented or non-vented gas cap?
Old Feb 17, 2004 | 05:26 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
I dont know if the gas cap is vented. but I think it is stock. How do I check to see If it is venting properly??
Old Mar 8, 2004 | 01:23 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
i had this prob. once and i replaced the white purge valve on the drivers underside frame and i also disconnected the return line as well as the vent line undercar and hood and blew compressed air through them both the prob. was gone....
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
