89 TPI intake and heads on 76 block
Old Feb 23, 2004 | 05:22 PM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
I've had a few guys tell me that that set-up will work. I still am concerned about the water ports matching up. Will they match up perfectly? or are they somewhat different?
Also I'm not exactly sure my engine is an L98. It orginally came with the 305(my car). I'm pretty sure it is. It has about the same power output.
I'm just worried about the water ports matching up. I wish I could do a better engine set-up. But I don't really see why this won't work out.
Old Feb 23, 2004 | 07:46 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Yes they will work on a 76 block. An L98 is a 350 not a 305.
Old Feb 23, 2004 | 08:49 PM
snowman89's Avatar
Engine: 5.8L 355
Yeah i know an L98 is a 350. I just didn't specify exactly. The 350 was swapped in place of the orginal 305.
So are the water ports like exactly alike??? like shape and everything?
Does anyone have a pic of a L98 head? showing the water ports and valves?
Old Feb 24, 2004 | 12:14 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
they are the same they used the same head gaskets for the 350s from 55 clear up till about the vortec engines and I think they might have used the same head gaskets for those but dont quote me on it. Easiest way to find out is call your local parts store and see which gasket they used for the 76 and 89 and Ill pretty much guarantee that they are the same, based off my 4+ years of parts store experience.
1992rs/ss
Jan 31, 2025 05:10 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
