tuned port removal
Old Feb 28, 2004 | 07:55 PM
miami1324's Avatar
Car: 1978 Monte Carlo
Engine: 358
Transmission: 350 turbo / hipster trans brake
tuned port removal
I am currently removing a 5.0 tuned port engine from an 87 trans am. It was over reeevvvveed and now knocks. I removed all the bolts from the tuned port runners and am missing something. The tubes seem to be stuck on the bottom. I do not see any more bolts. This seems to be the best site for 3rd gen. What am I missing ?
Old Feb 28, 2004 | 11:19 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well, if you have removed all the bolts from the runners including the two (one on each runner) that are mounted on the inner side of the runners. Then all that would be holding it would be the gaskets. Just tap with a mallet and they will come off. The two bolts I mentioned, (if you haven't already removed them) are located as follows.
Right runner = by the first tube.
Left runner = by the last tube (fun to get out)
Old Feb 29, 2004 | 06:40 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Moved.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
355tpipickup
Aug 13, 2015 07:35 AM
Jake_92RS
Aug 11, 2015 10:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
